[MOAB-dev] buildbot failure in moab-intel: failed test
    Tim Tautges
    tautges at mcs.anl.gov
    Fri May  3 09:12:39 CDT 2013
I'm sure this was my doing, I'll look into it.
- tim
On 05/03/2013 12:32 AM, moab-dev at mcs.anl.gov wrote:
>   Fathom <http://gnep.mcs.anl.gov:8010/>: moab-intel <http://gnep.mcs.anl.gov:8010/builders/moab-intel> build #177
>   <http://gnep.mcs.anl.gov:8010/builders/moab-intel/builds/177>
> *Results:*	failed test
> *Buildslave:*	gnep
> *Revision:*	None
> *Reason:*	The Nightly scheduler named 'moab-intel-nightly' triggered this build
>     Log Excerpt
> make[4]: Nothing to be done for `check-am'.
>   ...make[3]: Entering directory `/disks/itaps-buildslave/moab-intel/build/MeshFiles'
> make[3]: Nothing to be done for `check-am'.
>   ...Making check in itaps
> make[2]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps'
> Making check in imesh
> make[3]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
> make  check-am
> make[4]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
> make  testc_cbind MOAB_iMesh_unit_tests MOAB_iMesh_extensions_tests ScdMeshF90 ScdMeshF77 FindAdjacencyF90
> make[5]: Entering directory `/disks/itaps-buildslave/moab-intel/build/itaps/imesh'
> icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT testc_cbind.o -MD -MP -MF .deps/testc_cbind.Tpo -c -o testc_cbind.o testc_cbind.cpp
> mv -f .deps/testc_cbind.Tpo .deps/testc_cbind.Po
> /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o testc_cbind testc_cbind.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -l
 im
>   f -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu
 /4.
> libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o testc_cbind testc_cbind.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64
>   L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
> icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT MOAB_iMesh_unit_tests.o -MD -MP -MF .deps/MOAB_iMesh_unit_tests.Tpo -c -o MOAB_iMesh_unit_tests.o MOAB_iMesh_unit_tests.cpp
> mv -f .deps/MOAB_iMesh_unit_tests.Tpo .deps/MOAB_iMesh_unit_tests.Po
> /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib
 /x
>   86_64-linux-gnu -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/
 gcc
> libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o MOAB_iMesh_unit_tests MOAB_iMesh_unit_tests.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4
 .3
>   /../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
> icpc -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -MT MOAB_iMesh_extensions_tests.o -MD -MP -MF .deps/MOAB_iMesh_extensions_tests.Tpo -c -o MOAB_iMesh_extensions_tests.o MOAB_iMesh_extensions_tests.cpp
> mv -f .deps/MOAB_iMesh_extensions_tests.Tpo .deps/MOAB_iMesh_extensions_tests.Po
> /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/li
 b
>   -L/usr/lib/x86_64-linux-gnu -limf -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L.
  -L
> libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o MOAB_iMesh_extensions_tests MOAB_iMesh_extensions_tests.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-l
 in
>   ux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -ldecimal -lcilkrts -lstdc++ -lintlc -lgcc -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
> 	ifort -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/netcdf-4.1.3-intel/include    -I/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include -isystem /homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I./.. -I../../src -I../../src -I../../itaps -I../../test  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -O2  -c -o ScdMeshF90.o ScdMeshF90.F90
> /bin/sh ../../libtool  --tag=CXX   --mode=link icpc  -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib     -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib  -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib  -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib -o ScdMeshF90 ScdMeshF90.o libiMesh.la ../../src/libMOAB.la  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lim
 f
>   -lsvml -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc -lintlc -lgcc -lirc_s -ldl -lm  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../.. -L/lib -L/usr/lib64 -L/usr/lib -L/usr/lib/x86_64-linux-gnu -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl  -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib64 -L/lib/../lib -L/usr/lib/../lib64 -L/usr/lib/../lib -L/lib64 -L. -L/usr/lib/gcc/x86_64-linux-gnu/4
 .4.
> libtool: link: icpc -Wall -wd981 -wd279 -wd1418 -wd383 -wd1572 -wd2259 -O2 -DNDEBUG -o ScdMeshF90 ScdMeshF90.o  -L/homes/fathom/3rdparty/netcdf-4.1.3-intel/lib -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib -L/homes/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib ./.libs/libiMesh.a /disks/itaps-buildslave/moab-intel/build/src/.libs/libMOAB.a -L/disks/itaps-buildslave/moab-intel/build/src/io/mhdf -L/disks/itaps-buildslave/moab-intel/build/src/io -L/disks/itaps-buildslave/moab-intel/build/src -L/disks/itaps-buildslave/moab-intel/build/itaps/imesh ../../src/.libs/libMOAB.a /home/fathom/3rdparty/netcdf-4.1.3-intel/lib/libnetcdf.a /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5_hl.a /usr/lib/libcurl.so /home/fathom/3rdparty/hdf5-1.8.8-ser-intel/lib/libhdf5.a -lrt -lz -L/nfs/software/linux-ubuntu_lucid_amd64/com/packages/intel/12.0/339/composer_xe_2011_sp1.11.339/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64 -
 L/
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 0 has invalid symbol index 11
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 1 has invalid symbol index 12
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 2 has invalid symbol index 2
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 3 has invalid symbol index 2
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 4 has invalid symbol index 11
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 5 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 6 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 7 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 8 has invalid symbol index 2
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 9 has invalid symbol index 2
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 10 has invalid symbol index 12
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 11 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 12 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 13 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 14 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 15 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 16 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 17 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 18 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 19 has invalid symbol index 13
> ld: /usr/lib/debug/usr/lib/crt1.o(.debug_info): relocation 20 has invalid symbol index 20
> /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib64/crt1.o: In function `_start':
> (.text+0x20): undefined reference to `main'
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
