[MOAB-dev] commit/MOAB: tautges: Removing executable, adding .F90.
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu May 2 12:03:43 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d498bf05fd24/
Changeset:   d498bf05fd24
Branch:      master
User:        tautges
Date:        2013-05-02 19:03:27
Summary:     Removing executable, adding .F90.
Also missed Makefile.am in my previous commit.
Affected #:  3 files
diff --git a/examples/DirectAccessNoHolesF90 b/examples/DirectAccessNoHolesF90
deleted file mode 100755
index 1f44b63..0000000
Binary files a/examples/DirectAccessNoHolesF90 and /dev/null differ
diff --git a/examples/DirectAccessNoHolesF90.F90 b/examples/DirectAccessNoHolesF90.F90
new file mode 100644
index 0000000..3cf5fa7
--- /dev/null
+++ b/examples/DirectAccessNoHolesF90.F90
@@ -0,0 +1,231 @@
+! @example DirectAccessNoHolesF90.F90 \n
+! \brief Use direct access to MOAB data to avoid calling through API, in Fortran90 \n
+! This example creates a 1d row of quad elements, such that all quad and vertex handles
+! are contiguous in the handle space and in the database.  Then it shows how to get access
+! to pointers to MOAB-native data for vertex coordinates, quad connectivity, and tag storage
+! (vertex to quad adjacency lists aren't accessible from Fortran because they are std::vector's).
+! This allows applications to access this data directly
+! without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+! vertices are moving), this can save significant execution time in applications.
+! Using direct access (or MOAB in general) from Fortran is complicated in two specific ways:
+! 1) There is no way to use arrays with specified dimension starting/ending values with ISO_C_BINDING;
+!    therefore, all arrays passed back from MOAB/iMesh must use 1-based indices; this makes it a bit
+!    more difficult to traverse the direct arrays.  In this example, I explicitly use indices that
+!    look like my_array(1+v_ind...) to remind users of this.
+! 2) Arithmetic on handles is complicated by the fact that Fortran has no unsigned integer type.  I get
+!    around this by assigning to a C-typed variable first, before the handle arithmetic.  This seems to
+!    work fine.  C-typed variables are part of the Fortran95 standard.
+!    -#  Initialize MOAB \n
+!    -#  Create a quad mesh, as depicted above
+!    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+!    -#  Get connectivity, coordinate, tag1 iterators
+!    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+!    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+!    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+! <b>To compile</b>: \n
+!    make DirectAccessNoHolesF90 MOAB_DIR=<installdir>  \n
+! <b>To run</b>: ./DirectAccessNoHolesF90 [-nquads <# quads>]\n
+#define CHECK(a) \
+  if (a .ne. iBase_SUCCESS) call exit(a)
+module freem
+  interface
+     subroutine c_free(ptr) bind(C, name='free')
+       use ISO_C_BINDING
+       type(C_ptr), value, intent(in) :: ptr
+     end subroutine c_free
+  end interface
+end module freem
+program DirectAccessNoHolesF90
+  use ISO_C_BINDING
+  use freem
+  implicit none
+#include "iMesh_f.h"
+  ! declarations
+  iMesh_Instance imesh
+  iBase_EntitySetHandle root_set
+  integer ierr, nquads, nquads_tmp, nverts
+  iBase_TagHandle tag1h, tag2h, tag3h
+  TYPE(C_PTR) verts_ptr, quads_ptr, conn_ptr, x_ptr, y_ptr, z_ptr, tag1_ptr, tag2_ptr, tag3_ptr, &
+       tmp_quads_ptr, offsets_ptr  ! pointers that are equivalence'd to arrays using c_f_pointer
+  real(C_DOUBLE), pointer :: x(:), y(:), z(:), tag1(:), tag2(:) ! arrays equivalence'd to pointers
+  integer, pointer :: tag3(:), offsets(:)                       ! arrays equivalence'd to pointers
+  iBase_EntityHandle, pointer :: quads(:), verts(:), conn(:), tmp_quads(:)  ! arrays equivalence'd to pointers
+  iBase_EntityArrIterator viter, qiter
+  integer(C_SIZE_T) :: startv, startq, v_ind, e_ind  ! needed to do handle arithmetic
+  integer count, vpere, e, i, j, v, offsets_size, tmp_quads_size, n_dis
+  character*120 opt
+  ! initialize interface and get root set
+  call iMesh_newMesh("", imesh, ierr); CHECK(ierr)
+  call iMesh_getRootSet(%VAL(imesh), root_set, ierr); CHECK(ierr)
+  ! create mesh
+  nquads_tmp = 1000
+  call create_mesh_no_holes(imesh, nquads_tmp, ierr); CHECK(ierr)
+  ! get all vertices and quads as arrays
+  nverts = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(0), %VAL(iBase_VERTEX), &
+       verts_ptr, nverts, nverts, ierr); CHECK(ierr)
+  call c_f_pointer(verts_ptr, verts, [nverts])
+  nquads = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(2), %VAL(iMesh_QUADRILATERAL), &
+       quads_ptr, nquads, nquads, ierr); CHECK(ierr)
+  call c_f_pointer(quads_ptr, quads, [nquads])
+  ! First vertex/quad is at start of vertex/quad list, and is offset for vertex/quad index calculation
+  startv = verts(1); startq = quads(1)
+  call c_free(quads_ptr)  ! free memory we allocated in MOAB
+  ! create tag1 (element-based avg), tag2 (vertex-based avg)
+  opt = 'moab:TAG_STORAGE_TYPE=DENSE moab:TAG_DEFAULT_VALUE=0'
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag1', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag1h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag2', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag2h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  ! Get iterator to verts, then pointer to coordinates
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_VERTEX), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nverts), %VAL(0), viter, ierr); CHECK(ierr)
+  call iMesh_coordsIterate(%VAL(imesh), %VAL(viter), x_ptr, y_ptr, z_ptr, count, ierr); CHECK(ierr)
+  CHECK(count-nverts) ! check that all verts are in one contiguous chunk
+  call c_f_pointer(x_ptr, x, [nverts]); call c_f_pointer(y_ptr, y, [nverts]); call c_f_pointer(z_ptr, z, [nverts])
+  ! Get iterator to quads, then pointers to connectivity and tags
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_FACE), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nquads), %VAL(0), qiter, ierr); CHECK(ierr)
+  call iMesh_connectIterate(%VAL(imesh), %VAL(qiter), conn_ptr, vpere, count, ierr); CHECK(ierr)
+  call c_f_pointer(conn_ptr, conn, [vpere*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag1h), %VAL(qiter), tag1_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag1_ptr, tag1, [3*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag2h), %VAL(qiter), tag2_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag2_ptr, tag2, [3*nquads])
+  ! iterate over elements, computing tag1 from coords positions; use (1+... in array indices for 1-based indexing
+  do i = 0, nquads-1
+     tag1(1+3*i+0) = 0.0; tag1(1+3*i+1) = 0.0; tag1(1+3*i+2) = 0.0 ! initialize position for this element
+     do j = 0, vpere-1 ! loop over vertices in this quad
+        v_ind = conn(1+vpere*i+j) ! assign to v_ind to allow handle arithmetic
+        v_ind = v_ind - startv ! vert index is just the offset from start vertex
+        tag1(1+3*i+0) = tag1(1+3*i+0) + x(1+v_ind)
+        tag1(1+3*i+1) = tag1(1+3*i+1) + y(1+v_ind) ! sum vertex positions into tag1...
+        tag1(1+3*i+2) = tag1(1+3*i+2) + z(1+v_ind)
+     end do
+     tag1(1+3*i+0) = tag1(1+3*i+0) / vpere;
+     tag1(1+3*i+1) = tag1(1+3*i+1) / vpere; ! then normalize
+     tag1(1+3*i+2) = tag1(1+3*i+2) / vpere;
+  end do ! loop over elements in chunk
+  ! Iterate through vertices, summing positions into tag2 on connected elements; get adjacencies all at once,
+  ! could also get them per vertex (time/memory tradeoff)
+  tmp_quads_size = 0
+  offsets_size = 0
+  call iMesh_getEntArrAdj(%VAL(imesh), verts, %VAL(nverts), %VAL(iMesh_QUADRILATERAL), &
+       tmp_quads_ptr, tmp_quads_size, tmp_quads_size, &
+       offsets_ptr, offsets_size, offsets_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_quads_ptr, tmp_quads, [tmp_quads_size])
+  call c_f_pointer(offsets_ptr, offsets, [offsets_size])
+  call c_free(verts_ptr)  ! free memory we allocated in MOAB
+  do v = 0, nverts-1
+     do e = 1+offsets(1+v), 1+offsets(1+v+1)-1  ! 1+ because offsets are in terms of 0-based arrays
+        e_ind = tmp_quads(e) ! assign to e_ind to allow handle arithmetic
+        e_ind = e_ind - startq ! e_ind is the quad handle minus the starting quad handle
+        tag2(1+3*e_ind+0) = tag2(1+3*e_ind+0) + x(1+v)
+        tag2(1+3*e_ind+1) = tag2(1+3*e_ind+1) + y(1+v)   ! tag on each element is 3 doubles, x/y/z
+        tag2(1+3*e_ind+2) = tag2(1+3*e_ind+2) + z(1+v)
+     end do
+  end do
+  call c_free(tmp_quads_ptr)  ! free memory we allocated in MOAB
+  call c_free(offsets_ptr)    ! free memory we allocated in MOAB
+  ! Normalize tag2 by vertex count (vpere); loop over elements using same approach as before
+  ! At the same time, compare values of tag1 and tag2
+  n_dis = 0
+  do e = 0, nquads-1
+     do j = 0, 2
+        tag2(1+3*e+j) = tag2(1+3*e+j) / vpere;  ! normalize by # verts
+     end do
+     if (tag1(1+3*e) .ne. tag2(1+3*e) .or. tag1(1+3*e+1) .ne. tag2(1+3*e+1) .or. tag1(1+3*e+2) .ne. tag2(1+3*i+2)) then
+        print *, "Tag1, tag2 disagree for element ", e
+        print *, "tag1: ", tag1(1+3*e), tag1(1+3*e+1), tag1(1+3*e+2)
+        print *, "tag2: ", tag2(1+3*e), tag2(1+3*e+1), tag2(1+3*e+2)
+        n_dis = n_dis + 1
+     end if
+  end do
+  if (n_dis .eq. 0) print *, 'All tags agree, success!'
+    ! Ok, we are done, shut down MOAB
+  call iMesh_dtor(%VAL(imesh), ierr)
+  return
+end program DirectAccessNoHolesF90
+subroutine create_mesh_no_holes(imesh, nquads, ierr)
+  use ISO_C_BINDING
+  use freem
+  implicit none
+  integer nquads, ierr
+  real(C_DOUBLE), pointer :: coords(:,:)
+  TYPE(C_PTR) connect_ptr, tmp_ents_ptr, stat_ptr
+  iBase_EntityHandle, pointer :: connect(:), tmp_ents(:)
+  integer, pointer :: stat(:)
+  integer nverts, tmp_size, stat_size, i
+  ! first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ! create verts, num is 2(nquads+1) because they're in a 1d row
+  nverts = 2*(nquads+1)
+  allocate(coords(0:2, 0:nverts-1))
+     coords(0,2*i) = i; coords(0,2*i+1) = i ! x values are all i
+     coords(1,2*i) = 0.0; coords(1,2*i+1) = 1.0 ! y coords
+     coords(2,2*i) = 0.0; coords(2,2*i+1) = 0.0 ! z values, all zero (2d mesh)
+  end do
+  ! last two vertices
+  coords(0, nverts-2) = nquads; coords(0, nverts-1) = nquads
+  coords(1, nverts-2) = 0.0; coords(1, nverts-1) = 1.0 ! y coords
+  coords(2, nverts-2) = 0.0; coords(2, nverts-1) = 0.0 ! z values, all zero (2d mesh)
+  tmp_size = 0
+  call iMesh_createVtxArr(%VAL(imesh), %VAL(nverts), %VAL(iBase_INTERLEAVED), &
+       coords, %VAL(3*nverts), tmp_ents_ptr, tmp_size, tmp_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_ents_ptr, tmp_ents, [nverts])
+  deallocate(coords)
+  allocate(connect(0:4*nquads-1))
+     connect(4*i+0) = tmp_ents(1+2*i)
+     connect(4*i+1) = tmp_ents(1+2*i+2)
+     connect(4*i+2) = tmp_ents(1+2*i+3)
+     connect(4*i+3) = tmp_ents(1+2*i+1)
+  end do
+  stat_size = 0
+  stat_ptr = C_NULL_PTR
+  ! re-use tmp_ents here; we know it'll always be larger than nquads so it's ok
+  call iMesh_createEntArr(%VAL(imesh), %VAL(iMesh_QUADRILATERAL), connect, %VAL(4*nquads), &
+       tmp_ents_ptr, tmp_size, tmp_size, stat_ptr, stat_size, stat_size, ierr); CHECK(ierr)
+  ierr = iBase_SUCCESS
+  call c_free(tmp_ents_ptr)
+  call c_free(stat_ptr)
+  deallocate(connect)
+  return
+end subroutine create_mesh_no_holes
diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
index 647b8c1..97c76bb 100644
--- a/itaps/imesh/Makefile.am
+++ b/itaps/imesh/Makefile.am
@@ -45,6 +45,9 @@ if PARALLEL
 #  ftest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
 endif
+FCLINK = $(CXXLINK)
+F77LINK = $(CXXLINK)
 TESTS = $(check_PROGRAMS)
 LDADD = libiMesh.la $(top_builddir)/src/libMOAB.la ${MOAB_CXX_LINKFLAGS} ${MOAB_CXX_LIBS}
 TESTDEPS = libiMesh.la $(top_builddir)/src/libMOAB.la
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
