[MOAB-dev] commit/MOAB: tautges: Adding another direct access	example.
    commits-noreply at bitbucket.org
    Fri Apr 19 15:40:52 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5b851e8ef30e/
Changeset:   5b851e8ef30e
Branch:      master
User:        tautges
Date:        2013-04-19 22:40:40
Summary:     Adding another direct access example.
Affected #:  1 file
diff --git a/examples/DirectAccessNoHoles.cpp b/examples/DirectAccessNoHoles.cpp
new file mode 100644
index 0000000..445c517
--- /dev/null
+++ b/examples/DirectAccessNoHoles.cpp
@@ -0,0 +1,179 @@
+/** @example DirectAccess.cpp \n
+ * \brief Use direct access to MOAB data to avoid calling through API \n
+ * This example creates a 1d row of quad elements, with a user-specified number of "holes" (missing quads) in the row:
+ *  |      |      |      |(hole)|      |      |      |(hole)|      | ...
+ * This makes (nholes+1) contiguous runs of quad handles in the handle space
+ * This example shows how to use the xxx_iterate functions in MOAB (xxx = coords, connect, tag, adjacencies) to get
+ * direct pointer access to MOAB internal storage, which can be used without calling through the MOAB API.
+ *    -#  Initialize MOAB \n
+ *    -#  Create a quad mesh with holes, as depicted above
+ *    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+ *    -#  Get connectivity, coordinate, tag1 iterators
+ *    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+ *    -#  Set up map from starting quad handle for a chunk to struct of (tag1_ptr, tag2_ptr, tag3_ptr), pointers to
+ *        the dense tag storage for those tags for the chunk
+ *    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+ *    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+ * <b>To compile</b>: \n
+ *    make DirectAccessWithHoles MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: ./DirectAccess [-nquads <# quads>] [-holes <# holes>]\n
+#include "moab/Core.hpp"
+#include "moab/ProgOptions.hpp"
+#include "moab/ReadUtilIface.hpp"
+#include <map>
+#include <iostream>
+#include <assert.h>
+// Error routines for use with MOAB API
+#define CHKERR(CODE, MSG) do {if (MB_SUCCESS != (CODE)) {std::string errstr;  mbImpl->get_last_error(errstr);   \
+        std::cerr << errstr << std::endl; std::cerr << MSG << std::endl; return CODE;}} while(false)
+using namespace moab;
+ErrorCode create_mesh_no_holes(Interface *mbImpl, int nquads);
+int main(int argc, char **argv)
+    // get MOAB instance
+  Interface *mbImpl = new Core;
+  if (NULL == mbImpl) return 1;
+  int nquads = 1000;
+    // parse options
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("nquads,n"), std::string("Number of quads in the mesh (default = 1000"), &nquads);
+  opts.parseCommandLine(argc, argv);
+    // create simple structured mesh with hole, but using unstructured representation
+  ErrorCode rval = create_mesh_no_holes(mbImpl, nquads); CHKERR(rval, "Trouble creating mesh.");
+    // get all vertices and non-vertex entities
+  Range verts, quads;
+  rval = mbImpl->get_entities_by_handle(0, quads); CHKERR(rval, "Getting all entities.");
+  verts = quads.subset_by_dimension(0);
+  quads -= verts;
+    // create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts)
+  Tag tag1, tag2, tag3;
+  rval = mbImpl->tag_get_handle("tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT); CHKERR(rval, "Creating tag1.");
+  double def_val[3] = {0.0, 0.0, 0.0}; // need a default value for tag2 because we sum into it
+  rval = mbImpl->tag_get_handle("tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val); CHKERR(rval, "Creating tag2.");
+  int def_val_int = 0;  // need a default value for tag3 because we increment it
+  rval = mbImpl->tag_get_handle("tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int); CHKERR(rval, "Creating tag3.");
+    // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a count,
+    // which should be compared to the # entities you expect to verify there's only one chunk (no holes)
+  int count, vpere;
+  EntityHandle *conn_ptr;
+  rval = mbImpl->connect_iterate(quads.begin(), quads.end(), conn_ptr, vpere, count); CHKERR(rval, "connect_iterate.");
+  assert(count == (int) quads.size()); // should end up with just one contiguous chunk of quads
+  double *x_ptr, *y_ptr, *z_ptr;
+  rval = mbImpl->coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count); CHKERR(rval, "coords_iterate.");
+  assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
+  double *tag1_ptr, *tag2_ptr;
+  int *tag3_ptr;
+  rval = mbImpl->tag_iterate(tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr); CHKERR(rval, "tag1_iterate.");
+  rval = mbImpl->tag_iterate(tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr); CHKERR(rval, "tag2_iterate.");
+  rval = mbImpl->tag_iterate(tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr); CHKERR(rval, "tag3_iterate.");
+  const std::vector<EntityHandle> **adjs_ptr;
+  rval = mbImpl->adjacencies_iterate(verts.begin(), verts.end(), adjs_ptr, count); CHKERR(rval, "adjacencies_iterate.");
+    // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction because we know
+    // there aren't any holes in the handle spaces for verts or quads
+  EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin();
+    // iterate over elements, computing tag1 from coords positions
+  for (int i = 0; i < nquads; i++) {
+    tag1_ptr[3*i+0] = tag1_ptr[3*i+1] = tag1_ptr[3*i+2] = 0.0; // initialize position for this element
+    for (int j = 0; j < vpere; j++) { // loop over vertices in this element
+      int v_index = conn_ptr[vpere*i+j] - start_vert; // vert index is just the offset from start vertex
+      tag1_ptr[3*i+0] += x_ptr[v_index];
+      tag1_ptr[3*i+1] += y_ptr[v_index]; // sum vertex positions into tag1...
+      tag1_ptr[3*i+2] += z_ptr[v_index];
+    tag1_ptr[3*i+0] /= vpere;
+    tag1_ptr[3*i+1] /= vpere; // then normalize
+    tag1_ptr[3*i+2] /= vpere;
+  } // loop over elements in chunk
+    // Iterate through vertices, summing positions into tag2 on connected elements and incrementing vertex count
+  for (int v = 0; v < count; v++) {
+    const std::vector<EntityHandle> *avec = *(adjs_ptr+v);
+    for (std::vector<EntityHandle>::const_iterator ait = avec->begin(); ait != avec->end(); ait++) {
+        // *ait is the quad handle, its index is computed by subtracting the start quad handle
+      int a_ind = *ait - start_quad;
+      tag2_ptr[3*a_ind+0] += x_ptr[v];   // tag on each element is 3 doubles, x/y/z
+      tag2_ptr[3*a_ind+1] += y_ptr[v];
+      tag2_ptr[3*a_ind+2] += z_ptr[v];
+      tag3_ptr[a_ind]++;  // increment the vertex count
+    // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before
+    // At the same time, compare values of tag1 and tag2
+  for (Range::iterator q_it = quads.begin(); q_it != quads.end(); q_it++) {
+    int i = *q_it - start_quad;
+    for (int j = 0; j < 3; j++) tag2_ptr[3*i+j] /= (double)tag3_ptr[i];  // normalize by # verts
+    if (tag1_ptr[3*i] != tag2_ptr[3*i] || tag1_ptr[3*i+1] != tag2_ptr[3*i+1] || tag1_ptr[3*i+2] != tag2_ptr[3*i+2])
+      std::cout << "Tag1, tag2 disagree for element " << *q_it + i << std::endl;
+    // Ok, we're done, shut down MOAB
+  delete mbImpl;
+  return 0;
+    // first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ReadUtilIface *read_iface;
+  ErrorCode rval = mbImpl->query_interface(read_iface); CHKERR(rval, "query_interface");
+  std::vector<double *> coords;
+  EntityHandle start_vert, start_elem, *connect;
+    // create verts, num is 4(nquads+1) because they're in a 1d row; will initialize coords in loop over quads later
+  rval = read_iface->get_node_coords (3, 2*(nquads+1), 0, start_vert, coords); CHKERR(rval, "get_node_arrays");
+    // create quads
+  rval = read_iface->get_element_connect(nquads, 4, MBQUAD, 0, start_elem, connect); CHKERR(rval, "get_element_connect");
+    coords[0][2*i] = coords[0][2*i+1] = (double) i; // x values are all i
+    coords[1][2*i] = 0.0; coords[1][2*i+1] = 1.0; // y coords
+    coords[2][2*i] = coords[2][2*i+1] = (double) 0.0; // z values, all zero (2d mesh)
+    EntityHandle quad_v = start_vert + 2*i;
+    for (int j = 0; j < 4; j++) connect[4*i+j] = quad_v+j; // connectivity of each quad is a sequence starting from quad_v
+    // last two vertices
+  coords[0][2*nquads] = coords[0][2*nquads+1] = (double) nquads;
+  coords[1][2*nquads] = 0.0; coords[1][2*nquads+1] = 1.0; // y coords
+  coords[2][2*nquads] = coords[2][2*nquads+1] = (double) 0.0; // z values, all zero (2d mesh)
+    // call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB
+  Range dum_range;
+  rval = mbImpl->get_adjacencies(&start_vert, 1, 2, false, dum_range); CHKERR(rval, "get_adjacencies");
+  assert(!dum_range.empty());
+  return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
