[MOAB-dev] commit/MOAB: rajeeja: doxygen fixes for example
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Apr 16 09:21:37 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/446f2485fa34/
Changeset:   446f2485fa34
Branch:      master
User:        rajeeja
Date:        2013-04-16 16:21:23
Summary:     doxygen fixes for example
Affected #:  1 file
diff --git a/examples/StructuredMeshSimple.cpp b/examples/StructuredMeshSimple.cpp
index d357951..25aa08f 100644
--- a/examples/StructuredMeshSimple.cpp
+++ b/examples/StructuredMeshSimple.cpp
@@ -1,23 +1,23 @@
-/* \example StructuredMeshSimple StructuredMeshSimple.cpp
+/** @example StructuredMeshSimple.cpp
  * \brief Show creation and query of structured mesh, serial or parallel, through MOAB's structured mesh interface.
  * This is an example showing creation and query of a 3D structured mesh.  In serial, a single N*N*N block of elements
  * is created; in parallel, each proc gets an N*N*N block, with blocks arranged in a 1d column, sharing vertices
  * and faces at their interfaces (proc 0 has no left neighbor and proc P-1 no right neighbor).
  * Each square block of hex elements is then referenced by its ijk parameterization.
- * 1D and 2D examples could be made simply by changing the dimension parameter passed into the MOAB functions.
+ * 1D and 2D examples could be made simply by changing the dimension parameter passed into the MOAB functions. \n
- * This example:
- * 0. Instantiate MOAB and get the structured mesh interface
- * 1. Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
- * 2. Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
- * 3. Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d, resp.
- * 4. Loop over elements in d nested loops over i, j, k; for each (i,j,k):
- * 4a. Get the element corresponding to (i,j,k)
- * 4b. Get the connectivity of the element
- * 4c. Get the coordinates of the vertices comprising that element
- * 5. Release the structured mesh interface and destroy the MOAB instance
+ * <b>This example </b>:
+ *    -# Instantiate MOAB and get the structured mesh interface
+ *    -# Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
+ *    -# Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
+ *    -# Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d, resp.
+ *    -# Loop over elements in d nested loops over i, j, k; for each (i,j,k):
+ *      -# Get the element corresponding to (i,j,k)
+ *      -# Get the connectivity of the element
+ *      -# Get the coordinates of the vertices comprising that element
+ *    -# Release the structured mesh interface and destroy the MOAB instance
- * To run: ./structuredmesh [d [N] ]
+ * <b> To run: </b> ./structuredmesh [d [N] ] \n
  * (default values so can run w/ no user interaction)
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
