[MOAB-dev] commit/MOAB: iulian07: Adding more test and output files to ignore.
commits-noreply at bitbucket.org
Mon Apr 8 17:08:22 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/103b83a339b6/
Changeset: 103b83a339b6
Branch: master
User: iulian07
Date: 2013-04-09 00:07:33
Summary: Adding more test and output files to ignore.
Affected #: 1 file
diff --git a/.gitignore b/.gitignore
index fe08584..6b35368 100644
--- a/.gitignore
+++ b/.gitignore
@@ -22,6 +22,7 @@ configure
doc/config.tex
doc/dev.dox
doc/user.dox
+doc/user/*
examples/examples.make
itaps/iBase_f.h
itaps/igeom/FBiGeom-Defs.inc
@@ -66,3 +67,112 @@ lib/*
share/*
bin/*
+examples/HelloMoabPar
+itaps/igeom/FBiGeom_protos.h
+itaps/igeom/testSmooth2
+itaps/igeom/testSmoothGeom
+itaps/igeom/testgeom
+itaps/imesh/FindAdjacencyF90
+itaps/imesh/MOAB_iMeshP_unit_tests
+itaps/imesh/ScdMeshF77
+itaps/imesh/ScdMeshF90
+itaps/imesh/partest
+test/adaptive_kd_tree_tests
+test/bsp_tree_poly_test
+test/bsp_tree_test
+test/*.gen
+test/coords_connect_iterate
+test/cropvol_test
+test/dual/dual_test
+test/file_options_test
+test/geom_util_test
+test/gttool_test
+test/h5file/dump_sets
+test/h5file/h5legacy
+test/h5file/h5partial
+test/h5file/h5portable
+test/h5file/h5regression
+test/h5file/h5sets_test
+test/h5file/h5test
+test/h5file/h5varlen
+test/*.g
+test/homxform_test
+test/io/cub_file_test
+test/io/exodus_test
+test/io/gmsh_test
+test/io/ideas_test
+test/io/*.g
+test/io/nastran_test
+test/io/read_cgm_test
+test/io/read_nc
+test/io/read_ucd_nc
+test/io/readutil_test
+test/io/smf_test
+test/io/stl_test
+test/io/tqdcfr
+test/io/vtk_test
+test/kd_tree_test
+test/kd_tree_time
+test/kd_tree_tool
+test/mbcn_test
+test/mbfacet_test
+test/mbground_test
+test/mesh_set_test
+test/moab_test
+test/obb/obb_test
+test/obb/obb_time
+test/obb/obb_tree_tool
+test/obb_test
+test/oldinc/test_oldinc
+test/parallel/*.h5m
+test/parallel/*.vtk
+test/parallel/mbparallelcomm_test
+test/parallel/mhdf_parallel
+test/parallel/par_coupler_test
+test/parallel/par_intx_sph
+test/parallel/parallel_hdf5_test
+test/parallel/parallel_unit_tests
+test/parallel/parallel_write_test
+test/parallel/parmerge
+test/parallel/partcheck
+test/parallel/pcomm_serial
+test/parallel/pcomm_unit
+test/parallel/read_nc_par
+test/parallel/scdpart
+test/parallel/scdtest
+test/parallel/structured3
+test/parallel/uber_parallel_test
+test/parallel/ucdtrvpart
+test/perf/adj_time
+test/perf/perf
+test/perf/perftool
+test/perf/seqperf
+test/perf/tstt_perf_binding
+test/range_test
+test/reorder_test
+test/scdseq_test
+test/seq_man_test
+test/tag_test
+test/test_adj
+test/test_prog_opt
+test/var_len_test
+test/var_len_test_no_template
+test/xform_test
+tools/dagmc/pt_vol_test
+tools/dagmc/ray_fire_test
+tools/dagmc/test_geom
+tools/dagmc/update_coords
+tools/mbcoupler/*.h5m
+tools/mbcslam/case1_test
+tools/mbcslam/intersect1.h5m
+tools/mbcslam/intx.vtk
+tools/mbcslam/intx1.vtk
+tools/mbcslam/intx_in_plane_test
+tools/mbcslam/intx_on_sphere_test
+tools/mbcslam/lagr.h5m
+tools/mbcslam/spec_visu_test
+tools/mbcslam/spectral.vtk
+tools/mbcslam/spherical_area_test
+.project
+.cproject
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
