[MOAB-dev] Moved MOAB repo now
Tim Tautges
tautges at mcs.anl.gov
Wed Mar 13 12:42:54 CDT 2013
Hi all,
I've moved the MOAB repo over to a git repo on bitbucket.org now. Write access is turned off for the
subversion-based repo at ANL, and it's no longer being updated with changes on bitbucket. The bb repo is still
public-read; to write to it, you need to get a bb account, then email me the username, and I'll add you to the list.
The best way to interact with the bb-based repo, IMO, is to make a fork there (there's web support for doing that right
on the website there), then make a local clone of that fork (the command needed to make a clone is given by pulling down
the Clone pulldown when browsing the fork repo; copy that and execute it on your local machine).
To familiarize yourself with git, I'd recommend http://git-scm.com/book, at least through chapter 5. I also recommend
using a graphical tool like git-gui, which helps guide you through the commit process. Also, feel free to email
moab-dev with questions, so we can help each other through this transition.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
