[MOAB-dev] r6022 - MOAB/trunk/tools/mbcslam
iulian at mcs.anl.gov
Sun Mar 3 22:14:28 CST 2013
Author: iulian
Date: 2013-03-03 22:14:27 -0600 (Sun, 03 Mar 2013)
New Revision: 6022
Modified:
MOAB/trunk/tools/mbcslam/CslamUtils.cpp
MOAB/trunk/tools/mbcslam/CslamUtils.hpp
MOAB/trunk/tools/mbcslam/intx_on_sphere_test.cpp
MOAB/trunk/tools/mbcslam/spherical_area_test.cpp
Log:
use l'Huiller formula to compute the area of triangles on a sphere
http://williams.best.vwh.net/avform.htm
compared to Girard's formula, this is numerically better for small triangles
Modified: MOAB/trunk/tools/mbcslam/CslamUtils.cpp
--- MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2013-03-01 19:45:57 UTC (rev 6021)
+++ MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2013-03-04 04:14:27 UTC (rev 6022)
@@ -671,7 +671,66 @@
return Radius*Radius *correction;
+ * l'Huiller's formula for spherical triangle
+ * http://williams.best.vwh.net/avform.htm
+ * a, b, c are arc measures in radians, too
+ * A, B, C are angles on the sphere, for which we already have formula
+ * c
+ * A -------B
+ * \b |a
+ * \C|
+ * (The angle at B is not necessarily a right angle)
+ * sin(a) sin(b) sin(c)
+ * sin(A) sin(B) sin(C)
+ * In terms of the sides (this is excess, as before, but numerically stable)
+ * E = 4*atan(sqrt(tan(s/2)*tan((s-a)/2)*tan((s-b)/2)*tan((s-c)/2)))
+double area_spherical_triangle_lHuiller(double * ptA, double * ptB, double * ptC, double Radius)
+ // now, a is angle BOC, O is origin
+ CartVect vA(ptA), vB(ptB), vC(ptC);
+ double a = angle(vB, vC);
+ double b = angle(vC, vA);
+ double c = angle(vA, vB);
+ int sign =1;
+ if ((vA*vB)%vC < 0)
+ sign = -1;
+ double s = (a+b+c)/2;
+ double E = 4*atan(sqrt(tan(s/2)*tan((s-a)/2)*tan((s-b)/2)*tan((s-c)/2)));
+ return sign * E * Radius*Radius;
+double area_spherical_polygon_lHuiller (double * A, int N, double Radius)
