[MOAB-dev] r6015 - MOAB/trunk/tools/mbcslam
    iulian at mcs.anl.gov
    Mon Feb 25 16:31:50 CST 2013
Author: iulian
Date: 2013-02-25 16:31:50 -0600 (Mon, 25 Feb 2013)
New Revision: 6015
Modified:
   MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp
Log:
the arrival mesh could be disjoint, so the advancing front strategy
might stop
after processing each arrival element, remove it from the initial range;
stop when the initial range is empty
search for a new starting seed within the remaining elements;
Modified: MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp
--- MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp	2013-02-20 05:37:27 UTC (rev 6014)
+++ MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp	2013-02-25 22:31:50 UTC (rev 6015)
@@ -162,187 +162,192 @@
   Range rs2;
   mb->get_entities_by_type(mbs1, type, rs1);
   mb->get_entities_by_type(mbs2, type, rs2);
-  for (Range::iterator it = rs1.begin(); it != rs1.end(); it++)
+  while (!rs2.empty())
-    startBlue = *it;
-    int found = 0;
-    for (Range::iterator it2 = rs2.begin(); it2 != rs2.end() && !found; it2++)
+    for (Range::iterator it = rs1.begin(); it != rs1.end(); it++)
-      startRed = *it2;
-      double area = 0;
-      // if area is > 0 , we have intersections
-      double P[48]; // max 8 intx points + 8 more in the polygon
-      // the red quad is convex, always, while the blue can be concave
-      int nP = 0;
-      int nb[4], nr[4]; // sides 3 or 4? also, check boxes first
-      computeIntersectionBetweenRedAndBlue(startRed, startBlue, P, nP, area, nb, nr, true);
-      if (area > 0)
+      startBlue = *it;
+      int found = 0;
+      for (Range::iterator it2 = rs2.begin(); it2 != rs2.end() && !found; it2++)
-        found = 1;
-        break; // found 2 elements that intersect; these will be the seeds
+        startRed = *it2;
+        double area = 0;
+        // if area is > 0 , we have intersections
+        double P[48]; // max 8 intx points + 8 more in the polygon
+        // the red quad is convex, always, while the blue can be concave
+        int nP = 0;
+        int nb[4], nr[4]; // sides 3 or 4? also, check boxes first
+        computeIntersectionBetweenRedAndBlue(startRed, startBlue, P, nP, area, nb, nr, true);
+        if (area > 0)
+          found = 1;
+          break; // found 2 elements that intersect; these will be the seeds
+      if (found)
+        break;
-    if (found)
-      break;
