[MOAB-dev] buildbot failure in moab-cub-par-tru: failed configure
Iulian Grindeanu
iulian at mcs.anl.gov
Thu Feb 7 10:29:30 CST 2013
Sorry about this, please ignore the message; it was a setup problem .
Best Regards,
Iulian
----- Original Message -----
| Fathom : moab-cub-par-tru build #0
| Results: failed configure
| Buildslave: gnep
| Revision: None Log Excerpt
| checking for ccmio.h... no
| checking ccmioutility.h usability... no
| checking ccmioutility.h presence... no
| checking for ccmioutility.h... no
| checking ccmiocore.h usability... no
| checking ccmiocore.h presence... no
| checking for ccmiocore.h... no
| checking unsuccessful, Ccmio support disabled...
| checking if DAMSEL support is enabled... no
| checking if DAMSEL support available...
| checking if NetCDF support is enabled... yes
| checking netcdf.h usability... yes
| checking netcdf.h presence... yes
| checking for netcdf.h... yes
| checking if NC_MAX_DIMS is at least 65536... yes
| checking if NC_MAX_VARS is at least 524288... yes
| checking for nc_create in -lnetcdf... no
| checking for nc_create in -lnetcdf... yes
| checking if Pnetcdf support is enabled... yes
| checking pnetcdf.h usability... yes
| checking pnetcdf.h presence... yes
| checking for pnetcdf.h... yes
| checking if NC_MAX_DIMS is at least 65536... no
| checking if NC_MAX_VARS is at least 524288... no
| checking for ncmpi_create in -lpnetcdf... yes
| checking if mbconvert is to be built... yes
| checking if pointsearch is to be built... yes
| checking if hexmodops is to be built... yes
| checking if qvdual is to be built... no
| checking if vtkMOABReader is to be built... no
| checking if vtkMOABReaderNew is to be built... no
| checking if mbsize is to be built... yes
| checking if mbskin is to be built... yes
| checking if mbtagprop is to be built... yes
| checking if mbmem is to be built... yes
| checking if mcnpmit is to be built... no
| checking if mbcoupler is to be built... yes
| checking if spheredecomp is to be built... yes
| checking if mbsurfplot is to be built... yes
| checking if mbzoltan is to be built... yes
| checking if dagmc is to be built... yes
| checking if gsets is to be built... yes
| checking if mbdepth is to be built... yes
| checking if refiner is to be built... no
| checking if h5mtools is to be built... yes
| checking if mbcslam is to be built... no
| checking for zoltan_cpp.h... yes
| checking for Zoltan_LB_Partition in -lzoltan... no
| checking for Zoltan_LB_Partition in -lzoltan... yes
| configure: error: /homes/fathom/install/cubpartru/cgm : not a
| directory.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130207/503b6d19/attachment.html>
