[MOAB-dev] r5948 - MOAB/trunk/src/lotte
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Jan 22 12:54:11 CST 2013
Thanks Vijay.  This should fix the autotest errors of last night.
- tim
On 01/22/2013 12:37 PM, vijaysm at mcs.anl.gov wrote:
> Author: vijaysm
> Date: 2013-01-22 12:37:01 -0600 (Tue, 22 Jan 2013)
> New Revision: 5948
> Modified:
>     MOAB/trunk/src/lotte/poly.c
> Log:
> Removing a static keyword that got missed in the previous commit. Interesting this did not generate undefined errors on gcc-4.6.
> Modified: MOAB/trunk/src/lotte/poly.c
> --- MOAB/trunk/src/lotte/poly.c	2013-01-21 15:34:05 UTC (rev 5947)
> +++ MOAB/trunk/src/lotte/poly.c	2013-01-22 18:37:01 UTC (rev 5948)
> @@ -405,7 +405,7 @@
>       p->D2[i]=p->w[i]*(p->u2[i]*p->v0[i]+2*p->u1[i]*p->v1[i]+p->u0[i]*p->v2[i]);
> -static void lagrange_2u(lagrange_data *p)
> +void lagrange_2u(lagrange_data *p)
>     unsigned i,n=p->n;
>     for(i=0  ; i<n-1; ++i)
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
