[MOAB-dev] r5913 - in MOAB/trunk/src: . moab
    tautges at mcs.anl.gov
    Fri Dec 14 12:31:35 CST 2012
Author: tautges
Date: 2012-12-14 12:31:35 -0600 (Fri, 14 Dec 2012)
New Revision: 5913
Modified:
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/moab/Core.hpp
   MOAB/trunk/src/moab/Interface.hpp
Log:
Adding an optional argument to
    virtual ErrorCode  get_connectivity(const EntityHandle *entity_handles,
                                        const int num_handles,
                                        std::vector<EntityHandle> &connectivity,
                                        bool topological_connectivity = false,
                                        std::vector<int> *offsets = NULL) const;
for returning offsets into connectivity array; this allows applications to call
this function for higher-order entities and polyhedra/gons.  Resolves ticket 170.
Passes make check, serial and parallel.
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2012-12-14 16:28:51 UTC (rev 5912)
+++ MOAB/trunk/src/Core.cpp	2012-12-14 18:31:35 UTC (rev 5913)
@@ -1228,9 +1228,10 @@
 //! get the connectivity for element /handles.  For non-element handles, return an error
 ErrorCode  Core::get_connectivity(const EntityHandle *entity_handles,
-                                      const int num_handles,
-                                      std::vector<EntityHandle> &connectivity,
-                                      bool topological_connectivity) const
+                                  const int num_handles,
+                                  std::vector<EntityHandle> &connectivity,
+                                  bool topological_connectivity,
+                                  std::vector<int> *offsets) const
   connectivity.clear(); // this seems wrong as compared to other API functions,
                         // but changing it breaks lost of code, so I'm leaving
@@ -1240,11 +1241,13 @@
   std::vector<EntityHandle> tmp_storage; // used only for structured mesh
   const EntityHandle* conn;
   int len;
+  if (offsets) offsets->push_back(0);
   for (int i = 0; i < num_handles; ++i) {
     rval = get_connectivity( entity_handles[i], conn, len, topological_connectivity, &tmp_storage );
     if (MB_SUCCESS != rval)
       return rval;
     connectivity.insert( connectivity.end(), conn, conn + len );
+    if (offsets) offsets->push_back(connectivity.size());
   return MB_SUCCESS;
Modified: MOAB/trunk/src/moab/Core.hpp
--- MOAB/trunk/src/moab/Core.hpp	2012-12-14 16:28:51 UTC (rev 5912)
+++ MOAB/trunk/src/moab/Core.hpp	2012-12-14 18:31:35 UTC (rev 5913)
@@ -233,9 +233,10 @@
           std::vector<EntityHandle> conn;
           get_connectivity( entity_handle, conn ); \endcode */
-                                           bool topological_connectivity = false) const;
+                                        bool topological_connectivity = false,
+                                        std::vector<int> *offsets = NULL) const;
     //! Gets the connectivity for a vector of elements
     /** Same as vector-based version except range is returned (unordered!)
