[MOAB-dev] r5912 - in MOAB/trunk: src/moab test/parallel
tautges at mcs.anl.gov
Fri Dec 14 10:29:35 CST 2012
Author: tautges
Date: 2012-12-14 10:28:51 -0600 (Fri, 14 Dec 2012)
New Revision: 5912
Modified:
MOAB/trunk/src/moab/Skinner.hpp
MOAB/trunk/test/parallel/parallel_hdf5_test.cc
Log:
Adding a method to skinner that takes a handle vector instead of a range.
Adding a unit test for parallel reading of neumann/dirichlet/material sets.
Modified: MOAB/trunk/src/moab/Skinner.hpp
--- MOAB/trunk/src/moab/Skinner.hpp 2012-12-14 04:03:06 UTC (rev 5911)
+++ MOAB/trunk/src/moab/Skinner.hpp 2012-12-14 16:28:51 UTC (rev 5912)
@@ -19,6 +19,7 @@
#define MOAB_SKINNER_HPP
#include "moab/Forward.hpp"
+#include "moab/Range.hpp"
#include <vector>
namespace moab {
@@ -79,6 +80,32 @@
bool create_skin_elements = true,
bool look_for_scd = false);
+ /**\brief will accept entities all of one dimension and
+ * return entities of n-1 dimension; NOTE: get_vertices argument controls whether
+ * vertices or entities of n-1 dimension are returned, and only one of these is allowed
+ * (i.e. this function returns only vertices or (n-1)-dimensional entities, but not both)
+ * \param entities Pointer to elements for which to find the skin
+ * \param num_entities Number of entities in vector
+ * \param get_vertices If true, vertices on the skin are returned
+ * in the range, otherwise elements are returned
+ * \param output_handles Range holding skin entities returned
+ * \param output_reverse_handles Range holding entities on skin which
+ * are reversed wrt entities
+ * \param create_vert_elem_adjs If true, this function will cause
+ * vertex-element adjacencies to be generated
+ * \param create_skin_elements If true, this function will cause creation
+ * of skin entities, otherwise only skin entities already extant
+ * will be returned
+ ErrorCode find_skin( const EntityHandle *entities,
+ int num_entities,
+ bool get_vertices,
+ Range &output_handles,
+ Range *output_reverse_handles = 0,
+ bool create_vert_elem_adjs = false,
+ bool create_skin_elements = true,
+ bool look_for_scd = false);
/**\brief get skin entities of prescribed dimension
* \param entities The elements for which to find the skin
* \param dim Dimension of skin entities requested
@@ -254,6 +281,21 @@
bool create_skin_elements);
+inline ErrorCode Skinner::find_skin( const EntityHandle *entities,
+ int num_entities,
