[MOAB-dev] r5861 - MOAB/trunk/test/parallel
    iulian at mcs.anl.gov
    Fri Nov  9 15:24:37 CST 2012
Author: iulian
Date: 2012-11-09 15:24:37 -0600 (Fri, 09 Nov 2012)
New Revision: 5861
Modified:
   MOAB/trunk/test/parallel/ucdtrvpart.cpp
Log:
add a test for Homme spectral mesh in parallel;
it will just exercise the option, more work needs to be done to
match the "fine" nodes on the parallel interfaces
Modified: MOAB/trunk/test/parallel/ucdtrvpart.cpp
--- MOAB/trunk/test/parallel/ucdtrvpart.cpp	2012-11-09 18:38:05 UTC (rev 5860)
+++ MOAB/trunk/test/parallel/ucdtrvpart.cpp	2012-11-09 21:24:37 UTC (rev 5861)
@@ -13,7 +13,8 @@
 #endif
 void test_read_parallel_ucd_trivial();
-void test_read_parallel(int num_verts);
+void test_read_parallel_ucd_trivial_spectral();
+void test_read_parallel(int num_verts, bool test_nb_nodes);
 std::string partition_method;
@@ -34,11 +35,17 @@
   // disable spectral mesh for the time being, it is not ready yet
   partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS");
   //partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;SPECTRAL_MESH;PARALLEL_RESOLVE_SHARED_ENTS");
-  test_read_parallel(3458);
+  test_read_parallel(3458, true);
+  partition_method = std::string(";PARTITION_METHOD=TRIVIAL_PARTITION;SPECTRAL_MESH;PARALLEL_RESOLVE_SHARED_ENTS");
+  test_read_parallel(3458, false);
   Core moab;
   Interface& mb = moab;
   EntityHandle file_set;
@@ -69,7 +76,8 @@
   if (0 == pcomm->proc_config().proc_rank())
     std::cout<<"total vertices: " << total_verts << "\n";
-    CHECK_EQUAL(total_verts, num_verts);
+    if (test_nb_nodes)
+      CHECK_EQUAL(total_verts, num_verts);
   std::string write_options("PARALLEL=WRITE_PART;");
   mb.write_file( "test.h5m", NULL, write_options.c_str() );
