[MOAB-dev] r5860 - MOAB/trunk/src/io
iulian at mcs.anl.gov iulian at mcs.anl.gov
Fri Nov 9 12:38:05 CST 2012
Author: iulian
Date: 2012-11-09 12:38:05 -0600 (Fri, 09 Nov 2012)
New Revision: 5860
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
Log:
add one more tag to the file set, with the type of the mesh
it will be needed by the client
it is roughly the camType now, but it may extend later
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2012-11-09 18:10:27 UTC (rev 5859)
+++ MOAB/trunk/src/io/ReadNC.cpp	2012-11-09 18:38:05 UTC (rev 5860)
@@ -3365,6 +3365,30 @@
   if (MB_SUCCESS == rval)
     dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
+  // <__MESH_TYPE>
+  Tag meshTypeTag = 0;
+  tag_name = "__MESH_TYPE";
+  std::string meshTypeName;
+  switch(camType)
+  case CAM_EUL: meshTypeName="CAM_EUL"; break;
+  case CAM_FV: meshTypeName="CAM_FV"; break;
+  case CAM_SE: meshTypeName="CAM_SE"; break;
+  case CAM_UNKNOWN: meshTypeName="CAM_UNKNOWN"; break;
+  case NOT_CAM: meshTypeName="NOT_CAM"; break;
+  default: meshTypeName="NOT_CAM"; break;
+  rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+  ERRORR(rval, "Trouble creating __MESH_TYPE tag.");
+  ptr = meshTypeName.c_str();
+  int leng= meshTypeName.size();
+  rval = mbImpl->tag_set_by_ptr(meshTypeTag, &file_set, 1, &ptr, &leng);
+  ERRORR(rval, "Trouble setting data for __MESH_TYPE tag.");
+  if (MB_SUCCESS == rval)
+    dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
   return MB_SUCCESS;
