[MOAB-dev] buildbot failure in moab-occ-par: failed shell test
Iulian Grindeanu iulian at mcs.anl.gov
Thu Nov 1 09:39:12 CDT 2012
these should be mine, sorry about it.
The one with parallel write test is harder to explain. It could be some conflicts with the fact that we are using now
make -j4 check, to speed it up. ( parallel tests, we are also launching them with something like mpiexec -np 2 <test> )
Maybe there are some conflicts with that.
Iulian
----- Original Message -----
| Fathom : moab-occ-par build #42
| Results: failed shell test
| Buildslave: gnep
| Revision: None Log Excerpt
| Making check in igeom
| make[3]: Entering directory
| `/disks/itaps-buildslave/moab-occ-par/build/itaps/igeom'
| make check-am
| make[4]: Entering directory
| make testgeom testSmoothGeom testSmooth2
| make[5]: Entering directory
| /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx
| -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel
| -I../../src -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest/iGeom
| -I../../src -I../../src -I.. -I./.. -I../../itaps/imesh
| -I../../itaps/imesh -DUNORDERED_MAP_NS=std::tr1
| -DHAVE_UNORDERED_MAP=tr1/unordered_map
| -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -pipe -pedantic
| -Wno-long-long -O2 -DNDEBUG -MT testgeom.o -MD -MP -MF
| .deps/testgeom.Tpo -c -o testgeom.o testgeom.cc
| -Wno-long-long -O2 -DNDEBUG -MT testSmooth.o -MD -MP -MF
| .deps/testSmooth.Tpo -c -o testSmooth.o testSmooth.cc
| -Wno-long-long -O2 -DNDEBUG -MT testSmooth2.o -MD -MP -MF
| .deps/testSmooth2.Tpo -c -o testSmooth2.o testSmooth2.cc
| mv -f .deps/testgeom.Tpo .deps/testgeom.Po
| /bin/sh ../../libtool --tag=CXX --mode=link
| /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe
| -pedantic -Wno-long-long -O2 -DNDEBUG
| -R/homes/fathom/install/occpar/cgm/lib
| -L/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc/lib
| -L/homes/fathom/3rdparty/zlib/zlib-1.2.4/gcc/lib
| -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib
| -L/homes/fathom/install/occpar/cgm/lib
| -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
| -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o testgeom
| testgeom.o libFBiGeomMOAB.la ../../itaps/imesh/libiMesh.la
| ../../src/libMOAB.la
| -L/home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/lib
| -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3
| -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -L/usr/lib/gcc/x86_64-linux-gnu/
| 4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib
| -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../..
| -L/usr/lib/x86_64-linux-gnu -lmpichcxx -lmpich -lopa -lpthread -lrt
| -lstdc++ -lm
| mv -f .deps/testSmooth.Tpo .deps/testSmooth.Po
| testSmoothGeom testSmooth.o libFBiGeomMOAB.la
| ../../itaps/imesh/libiMesh.la ../../src/libMOAB.la
| nux-gnu/4.4.3/../../../../lib -L/lib/../lib -L/usr/lib/../lib
| -lstdc++ -lm
| libtool: link:
| -pedantic -Wno-long-long -O2 -DNDEBUG -o .libs/testgeom testgeom.o
| ./.libs/libFBiGeomMOAB.so ../../itaps/imesh/.libs/libiMesh.so
| ../../src/.libs/libMOAB.so
| -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../../lib -L/lib/../lib
| -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../..
| -lstdc++ -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/moab/lib
| -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib
| mv -f .deps/testSmooth2.Tpo .deps/testSmooth2.Po
| testSmooth2 testSmooth2.o libFBiGeomMOAB.la
| -lstdc++ -lm
| libtool: link:
| -pedantic -Wno-long-long -O2 -DNDEBUG -o .libs/testSmoothGeom
| testSmooth.o
| libtool: link:
| -pedantic -Wno-long-long -O2 -DNDEBUG -o .libs/testSmooth2
| testSmooth2.o
| ...make check-TESTS
| make[6]: Entering directory
| [0;32mPASS[m: testgeom
| [0;32mPASS[m: testSmoothGeom
| [0;32mPASS[m: testSmooth2
| [0;32m==================
| All 3 tests passed
| [mmake[6]: Leaving directory
| ...make[3]: Entering directory
| `/disks/itaps-buildslave/moab-occ-par/build/itaps'
| make[3]: Nothing to be done for `check-am'.
| ...Making check in tools
| make[2]: Entering directory
| `/disks/itaps-buildslave/moab-occ-par/build/tools'
| Making check in .
| ...Making check in mbcoupler
| `/disks/itaps-buildslave/moab-occ-par/build/tools/mbcoupler'
| -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o addfield
| addfield.o libmbcoupler.la -lm
| -L/homes/fathom/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib -o ssn_test
| ssn_test.o libmbcoupler.la -lm
| libtool: link:
| -pedantic -Wno-long-long -O2 -DNDEBUG -o .libs/addfield addfield.o
| ./.libs/libmbcoupler.so -lm -Wl,-rpath
| -Wl,/homes/fathom/install/occpar/moab/lib -Wl,-rpath
| libtool: link:
| -pedantic -Wno-long-long -O2 -DNDEBUG -o .libs/ssn_test ssn_test.o
| ./.libs/libmbcoupler.so: undefined reference to `opt_alloc_2'
| ./.libs/libmbcoupler.so: undefined reference to `opt_free_2'
| ./.libs/libmbcoupler.so: undefined reference to `opt_findpt_2'
| collect2: ld returned 1 exit status
| ...make[3]: *** Waiting for unfinished jobs....
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121101/8d9cf843/attachment-0001.html>
