[MOAB-dev] r5819 - in MOAB/trunk: . examples/moabuse
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Mon Oct 22 14:56:58 CDT 2012
----- Original Message -----
| | Author: milad
| | Date: 2012-10-22 14:50:27 -0500 (Mon, 22 Oct 2012)
| | New Revision: 5819
| | Added:
| | MOAB/trunk/examples/moabuse/README.moabuse.in
| | MOAB/trunk/examples/moabuse/mberr.hpp.in
| | MOAB/trunk/examples/moabuse/moabuse1.cpp.in
| | MOAB/trunk/examples/moabuse/moabuse2.cpp.in
| | MOAB/trunk/examples/moabuse/moabuse3.cpp.in
| | MOAB/trunk/examples/moabuse/moabuse4.cpp.in
| | Removed:
| | Modified:
| | MOAB/trunk/configure.ac
| | Log:
| | Renamed all of the files in the moabuse example so that they end in
| | ".in". This prevents a configure error encountered by several people
| | when doing installing in the source directory.
| I think the correct solution would be to just add Makefile.am there.
| Makefile.in and all *.in files should not be created during configure.
| (so look at examples/Makefile.am)
Of course, I meant that all these *.in files will be used by configure to generate the files. They should not be part of repository
| Why do you need to recreate README.moabuse as part of configure?
| | Modified: MOAB/trunk/configure.ac
| | --- MOAB/trunk/configure.ac 2012-10-22 15:38:48 UTC (rev 5818)
| | +++ MOAB/trunk/configure.ac 2012-10-22 19:50:27 UTC (rev 5819)
| | @@ -1188,12 +1188,12 @@
| | examples/simple/makefile
| | examples/itaps/Makefile
| | examples/moabuse/Makefile
| | - examples/moabuse/README.moabuse:examples/moabuse/README.moabuse
| | - examples/moabuse/mberr.hpp:examples/moabuse/mberr.hpp
| | - examples/moabuse/moabuse1.cpp:examples/moabuse/moabuse1.cpp
| | - examples/moabuse/moabuse2.cpp:examples/moabuse/moabuse2.cpp
| | - examples/moabuse/moabuse3.cpp:examples/moabuse/moabuse3.cpp
| | - examples/moabuse/moabuse4.cpp:examples/moabuse/moabuse4.cpp
| | + examples/moabuse/README.moabuse
| | + examples/moabuse/mberr.hpp
| | + examples/moabuse/moabuse1.cpp
| | + examples/moabuse/moabuse2.cpp
| | + examples/moabuse/moabuse3.cpp
| | + examples/moabuse/moabuse4.cpp
| | MeshFiles/Makefile
| | MeshFiles/unittest/Makefile
| | MeshFiles/unittest/io/Makefile
| | Deleted: MOAB/trunk/examples/moabuse/README.moabuse
| | --- MOAB/trunk/examples/moabuse/README.moabuse 2012-10-22 15:38:48
| | UTC
| | (rev 5818)
| | +++ MOAB/trunk/examples/moabuse/README.moabuse 2012-10-22 19:50:27
| | UTC
| | (rev 5819)
| | @@ -1,19 +0,0 @@
| | -The moabuse tutorial
| | -The source files in this directory define a set of examples that
| | -constitute the moabuse tutorial. This tutorial is meant to
| | demonstrate
| | -the functionality of the MOAB library beginning with very simple
| | -examples. If you are new to MOAB, start with the first one
| | -(moabuse1.cpp) then work your way through. READ THE COMMENTS. Later
| | -examples assume you have looked at previous ones.
| | -Each source file in the tutorial should be compiled as a separate
| | -program and linked to MOAB. Each example includes the "mberr.hpp"
| | -header file as well.
| | -There should be a Makefile in the examples/moabuse directory. Just
| | -type "make" to build all of the examples or "make moabuseN" to
| | build
| | -example N.
| | Copied: MOAB/trunk/examples/moabuse/README.moabuse.in (from rev
| | 5809,
| | MOAB/trunk/examples/moabuse/README.moabuse)
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121022/998b31e1/attachment-0001.html>
