[MOAB-dev] r5819 - in MOAB/trunk: . examples/moabuse
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Mon Oct 22 14:54:42 CDT 2012
----- Original Message -----
| Author: milad
| Date: 2012-10-22 14:50:27 -0500 (Mon, 22 Oct 2012)
| New Revision: 5819
| Added:
| MOAB/trunk/examples/moabuse/README.moabuse.in
| MOAB/trunk/examples/moabuse/mberr.hpp.in
| MOAB/trunk/examples/moabuse/moabuse1.cpp.in
| MOAB/trunk/examples/moabuse/moabuse2.cpp.in
| MOAB/trunk/examples/moabuse/moabuse3.cpp.in
| MOAB/trunk/examples/moabuse/moabuse4.cpp.in
| Removed:
| Modified:
| MOAB/trunk/configure.ac
| Log:
| Renamed all of the files in the moabuse example so that they end in
| ".in". This prevents a configure error encountered by several people
| when doing installing in the source directory.
I think the correct solution would be to just add Makefile.am there.
Makefile.in and all *.in files should not be created during configure. (so look at examples/Makefile.am)
Why do you need to recreate README.moabuse as part of configure?
| Modified: MOAB/trunk/configure.ac
| --- MOAB/trunk/configure.ac 2012-10-22 15:38:48 UTC (rev 5818)
| +++ MOAB/trunk/configure.ac 2012-10-22 19:50:27 UTC (rev 5819)
| @@ -1188,12 +1188,12 @@
| examples/simple/makefile
| examples/itaps/Makefile
| examples/moabuse/Makefile
| - examples/moabuse/README.moabuse:examples/moabuse/README.moabuse
| - examples/moabuse/mberr.hpp:examples/moabuse/mberr.hpp
| - examples/moabuse/moabuse1.cpp:examples/moabuse/moabuse1.cpp
| - examples/moabuse/moabuse2.cpp:examples/moabuse/moabuse2.cpp
| - examples/moabuse/moabuse3.cpp:examples/moabuse/moabuse3.cpp
| - examples/moabuse/moabuse4.cpp:examples/moabuse/moabuse4.cpp
| + examples/moabuse/README.moabuse
| + examples/moabuse/mberr.hpp
| + examples/moabuse/moabuse1.cpp
| + examples/moabuse/moabuse2.cpp
| + examples/moabuse/moabuse3.cpp
| + examples/moabuse/moabuse4.cpp
| MeshFiles/Makefile
| MeshFiles/unittest/Makefile
| MeshFiles/unittest/io/Makefile
| Deleted: MOAB/trunk/examples/moabuse/README.moabuse
| --- MOAB/trunk/examples/moabuse/README.moabuse 2012-10-22 15:38:48 UTC
| (rev 5818)
| +++ MOAB/trunk/examples/moabuse/README.moabuse 2012-10-22 19:50:27 UTC
| (rev 5819)
| @@ -1,19 +0,0 @@
| -The moabuse tutorial
| -The source files in this directory define a set of examples that
| -constitute the moabuse tutorial. This tutorial is meant to
| demonstrate
| -the functionality of the MOAB library beginning with very simple
| -examples. If you are new to MOAB, start with the first one
| -(moabuse1.cpp) then work your way through. READ THE COMMENTS. Later
| -examples assume you have looked at previous ones.
| -Each source file in the tutorial should be compiled as a separate
| -program and linked to MOAB. Each example includes the "mberr.hpp"
| -header file as well.
| -There should be a Makefile in the examples/moabuse directory. Just
| -type "make" to build all of the examples or "make moabuseN" to build
| -example N.
| Copied: MOAB/trunk/examples/moabuse/README.moabuse.in (from rev 5809,
| MOAB/trunk/examples/moabuse/README.moabuse)
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121022/3bdc66ca/attachment.html>
