[MOAB-dev] r5668 - in MOAB/trunk: src/moab/point_locater tools
rhl6856 at mcs.anl.gov
Fri Aug 3 13:37:25 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:25 -0500 (Fri, 03 Aug 2012)
New Revision: 5668
Modified:
MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
MOAB/trunk/src/moab/point_locater/common_tree.hpp
MOAB/trunk/src/moab/point_locater/element_tree.hpp
MOAB/trunk/tools/point_search.cpp
Log:
removed Box_with_center for now. things compile. need to implement bvh build rules
Modified: MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
--- MOAB/trunk/src/moab/point_locater/bvh_tree.hpp 2012-08-03 18:37:24 UTC (rev 5667)
+++ MOAB/trunk/src/moab/point_locater/bvh_tree.hpp 2012-08-03 18:37:25 UTC (rev 5668)
@@ -42,7 +42,10 @@
}; // _Node
struct _Split_data {
+ unsigned int dim;
+ unsigned int child;
+ float Lmax, Rmin;
+ unsigned int nl;
}; //_Split_data
@@ -82,46 +85,77 @@
bounding_box( _bounding_box),
entity_contains( entity_contains){
typedef typename Entity_handles::iterator Entity_handle_iterator;
- typedef typename std::map< Entity_handle, Box> Entity_map;
+ typedef common_tree::_Element_data< _Box, int > Element_data;
+ typedef typename std::tr1::unordered_map< Entity_handle,
+ Element_data> Entity_map;
typedef typename Entity_map::iterator Entity_map_iterator;
typedef std::vector< Entity_map_iterator> Vector;
//a fully balanced tree will have 2*_entities.size()
//which is one doubling away..
tree_.reserve( entity_handles_.size());
- Entity_map entity_map;
+ Entity_map entity_map( entity_handles_.size());
common_tree::construct_element_map( entity_handles_,
entity_map,
bounding_box,
moab);
- _bounding_box = bounding_box;
+ std::cout << "construct map ? " << std::endl;
+ //_bounding_box = bounding_box;
Vector entity_ordering;
construct_ordering( entity_map, entity_ordering);
//We only build nonempty trees
+ std::cout << "ordering" << std::endl;
if( entity_ordering.size()){
//initially all bits are set
tree_.push_back( Node());
- _bvh::_Split_data data;
const int depth = build_tree( entity_ordering.begin(),
- entity_ordering.end(), 0, data);
+ entity_ordering.end(), 0);
std::cout << "max tree depth: " << depth << std::endl;
