[MOAB-dev] r5614 - MOAB/trunk/test/parallel
    iulian at mcs.anl.gov
    Fri Jun 29 11:15:07 CDT 2012
Author: iulian
Date: 2012-06-29 11:15:07 -0500 (Fri, 29 Jun 2012)
New Revision: 5614
Modified:
   MOAB/trunk/test/parallel/Makefile.am
Log:
recursive error
Modified: MOAB/trunk/test/parallel/Makefile.am
--- MOAB/trunk/test/parallel/Makefile.am	2012-06-29 16:10:58 UTC (rev 5613)
+++ MOAB/trunk/test/parallel/Makefile.am	2012-06-29 16:15:07 UTC (rev 5614)
@@ -14,7 +14,7 @@
 # Run parallel tests in parallel
 if USE_MPIEXEC
-  OLD_ENVIRONMENT = ${TESTS_ENVIRONMENT}
+  OLD_ENVIRONMENT := ${TESTS_ENVIRONMENT}
   TESTS_ENVIRONMENT = ${MPIEXEC} ${MPIEXEC_NP} ${NP} ${OLD_ENVIRONMENT}
 endif
