[MOAB-dev] r5613 - MOAB/branches/NCparperiodic/test/parallel
    iulian at mcs.anl.gov
    Fri Jun 29 11:10:58 CDT 2012
Author: iulian
Date: 2012-06-29 11:10:58 -0500 (Fri, 29 Jun 2012)
New Revision: 5613
Modified:
   MOAB/branches/NCparperiodic/test/parallel/Makefile.am
Log:
revert a change from yesterday with respect to := assignments not portable
I think it was committed on the trunk too, by Ryan
It can't run tests without it
Modified: MOAB/branches/NCparperiodic/test/parallel/Makefile.am
--- MOAB/branches/NCparperiodic/test/parallel/Makefile.am	2012-06-29 15:57:34 UTC (rev 5612)
+++ MOAB/branches/NCparperiodic/test/parallel/Makefile.am	2012-06-29 16:10:58 UTC (rev 5613)
@@ -14,7 +14,7 @@
 # Run parallel tests in parallel
 if USE_MPIEXEC
-  OLD_ENVIRONMENT = ${TESTS_ENVIRONMENT}
+  OLD_ENVIRONMENT := ${TESTS_ENVIRONMENT}
   TESTS_ENVIRONMENT = ${MPIEXEC} ${MPIEXEC_NP} ${NP} ${OLD_ENVIRONMENT}
 endif
