[MOAB-dev] Incoming changes to structured mesh interface
    Steve Jackson
    sjackson at cae.wisc.edu
    Wed Jun 27 07:59:06 CDT 2012
Hi Tim,
Will these upcoming changes affect iMesh_createStructuredMesh()?  (I'm particularly wondering about the pytaps interface to this function; in the contexts where we use it, all our meshes are serial and non-periodic.)
~S
On Jun 26, 2012, at 15:31 , Tim Tautges wrote:
> Hi all,
>  Some fairly major API changes are incoming to the structured mesh interface (ScdInterface).  In a nutshell, I'm changing the API functions to pass is_periodic information as an int[2] rather than as 2 bools.  Also, I'm making the periodic structured mesh and parallel structured mesh functionality play nicely together, which they haven't really done before.  These changes shouldn't affect most users, and if you don't care about doing periodic or parallel structured mesh, most arguments have defaults that get you what you had before.  If anybody needs help converting their code over, let me know.  Thanks.
> - tim
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
