[MOAB-dev] Incoming changes to structured mesh interface
Tim Tautges
tautges at mcs.anl.gov
Tue Jun 26 16:31:51 CDT 2012
Hi all,
Some fairly major API changes are incoming to the structured mesh interface (ScdInterface). In a nutshell, I'm
changing the API functions to pass is_periodic information as an int[2] rather than as 2 bools. Also, I'm making the
periodic structured mesh and parallel structured mesh functionality play nicely together, which they haven't really done
before. These changes shouldn't affect most users, and if you don't care about doing periodic or parallel structured
mesh, most arguments have defaults that get you what you had before. If anybody needs help converting their code over,
let me know. Thanks.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
