[MOAB-dev] r5585 - in MOAB/trunk: MeshFiles/unittest/io src/io	test/io test/parallel
    xbxu at mcs.anl.gov
    xbxu at mcs.anl.gov
    Fri Jun 22 14:00:41 CDT 2012
Author: xbxu
Date: 2012-06-22 14:00:40 -0500 (Fri, 22 Jun 2012)
New Revision: 5585
Added:
   MOAB/trunk/MeshFiles/unittest/io/camEul26x48x96.t3.nc
Removed:
   MOAB/trunk/MeshFiles/unittest/io/cam18x40x48.t2.nc
Modified:
   MOAB/trunk/MeshFiles/unittest/io/Makefile.am
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/io/ReadNC.hpp
   MOAB/trunk/test/io/read_nc.cpp
   MOAB/trunk/test/parallel/Makefile.am
   MOAB/trunk/test/parallel/scdpart.cpp
Log:
merge the branch nc_to_2.5d back to trunk
Modified: MOAB/trunk/MeshFiles/unittest/io/Makefile.am
--- MOAB/trunk/MeshFiles/unittest/io/Makefile.am	2012-06-20 16:51:10 UTC (rev 5584)
+++ MOAB/trunk/MeshFiles/unittest/io/Makefile.am	2012-06-22 19:00:40 UTC (rev 5585)
@@ -1,7 +1,7 @@
 EXTRA_DIST = brick_cubit10.1.cub \
              brick_cubit10.2.cub \
              brick_cubit10.cub \
-	     cam18x40x48.t2.nc \
+             camEul26x48x96.t3.nc \
 	     cubtest12.cub \
 	     cubtest.jou \
 	     dum.sat \
Deleted: MOAB/trunk/MeshFiles/unittest/io/cam18x40x48.t2.nc
(Binary files differ)
Added: MOAB/trunk/MeshFiles/unittest/io/camEul26x48x96.t3.nc
Property changes on: MOAB/trunk/MeshFiles/unittest/io/camEul26x48x96.t3.nc
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2012-06-20 16:51:10 UTC (rev 5584)
+++ MOAB/trunk/src/io/ReadNC.cpp	2012-06-22 19:00:40 UTC (rev 5585)
@@ -5,6 +5,7 @@
 #include <stdio.h>
 #include <string.h>
 #include <cmath>
+#include <cstdlib>
 #include <iostream>
 #include <sstream>
 #include <map>
@@ -30,10 +31,13 @@
 ReadNC::ReadNC(Interface* impl)
         : mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1),
           tMin(-1), tMax(-1),
-          iDim(-1), jDim(-1), kDim(-1), tDim(-1), numUnLim(-1), mCurrentMeshHandle(0),
+	  iDim(-1), jDim(-1), tDim(-1), iCDim(-1), jCDim(-1),
+	  numUnLim(-1), mCurrentMeshHandle(0),
           startVertex(0), startElem(0), mGlobalIdTag(0),
           max_line_length(-1), max_str_length(-1), vertexOffset(0), dbgOut(stderr),
-          isParallel(false), partMethod(-1), ucdMesh(false)
+          isParallel(false), partMethod(-1), ucdMesh(false),
