[MOAB-dev] r5584 - MOAB/trunk/tools/dagmc
    sjackson at cae.wisc.edu
    Wed Jun 20 11:51:10 CDT 2012
Author: sjackson
Date: 2012-06-20 11:51:10 -0500 (Wed, 20 Jun 2012)
New Revision: 5584
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
   MOAB/trunk/tools/dagmc/DagMC.hpp
   MOAB/trunk/tools/dagmc/obb_analysis.cpp
Log:
Allow DagMC properties to have multiple values
A single property can now have multiple values set on a single volume
or surface.  This changes the internal implementation of the property
system, but the public interface is the same except for a single new
function prop_values()
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2012-06-18 18:51:44 UTC (rev 5583)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2012-06-20 16:51:10 UTC (rev 5584)
@@ -1687,6 +1687,58 @@
   return MB_SUCCESS;
+ErrorCode DagMC::append_packed_string( Tag tag, EntityHandle eh,
+                                       std::string& new_string )
+    // When properties have multiple values, the values are tagged in a single character array
+    // with the different values separated by null characters
+  ErrorCode rval;
+  const void* p;
+  const char* str;
+  int len;
+  rval = MBI->tag_get_by_ptr( tag, &eh, 1, &p, &len );
+  if( rval == MB_TAG_NOT_FOUND ){
+    // This is the first entry, and can be set directly
+    p = new_string.c_str();
+    return MBI->tag_clear_data( tag, &eh, 1, p, new_string.length()+1);
+  else if( rval != MB_SUCCESS ) return rval;
+  else{
+    str = static_cast<const char*>(p);
+  // append a new value for the property to the existing property string
+  unsigned int tail_len = new_string.length() + 1;
+  char* new_packed_string = new char[ len + tail_len ];
+  memcpy( new_packed_string, str, len );
+  memcpy( new_packed_string + len, new_string.c_str(), tail_len );
+  int new_len = len + tail_len;
+  p = new_packed_string;
+  rval = MBI->tag_set_by_ptr( tag, &eh, 1, &p, &new_len );
+  delete[] new_packed_string;
+  return rval;
+ErrorCode DagMC::unpack_packed_string( Tag tag, EntityHandle eh,
+                                       std::vector< std::string >& values )
+  ErrorCode rval;
+  const void* p;
+  const char* str;
+  int len;
+  if( rval != MB_SUCCESS ) return rval;
