[MOAB-dev] make check on 4.5 branch with gcc-4.1.2
    Mark Miller
    miller86 at llnl.gov
    Wed May 30 14:20:03 CDT 2012
Ok. I probably have a silly question then.
I am looking for 'iGeom' data files that represent either b-rep or csg
solid models that I will then discretize using either functions in iGeom
implementation or in VisIt so that I can load them into VisIt like a
'normal' mesh and visualize them.
I thought .h5m files were essentially already discretized
representations. Do they include b-rep or csg-rep of solid models too?
If so, can you tell me where to find a few (small) example files I can
play with?
On Wed, 2012-05-30 at 11:28 -0700, Iulian Grindeanu wrote:
>         On 05/30/2012 01:09 PM, Mark Miller wrote:
>         > Ok, thats what I thought.
>         > Another question. Should I expect the igeom test codes in
>         itaps/igeom,
>         > like testSmooth, to be able to read bricks.stp? I am getting
>         segv's with
>         > it whereas it is reading the default .h5m file ok I guess.
> igeom test codes in moab/itaps/igeom will work with moab h5m files
> only, they are using moab igeom implementation.
> It is my fault that it is not bailing out more gracefully if the files
> are not h5m.
> Iulian
Mark C. Miller, Lawrence Livermore National Laboratory
================!!LLNL BUSINESS ONLY!!================
miller86 at llnl.gov      urgent: miller86 at pager.llnl.gov
T:8-6 (925)-423-5901    M/W/Th:7-12,2-7 (530)-753-8511
