[MOAB-dev] make check on 4.5 branch with gcc-4.1.2
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed May 30 13:28:04 CDT 2012
| On 05/30/2012 01:09 PM, Mark Miller wrote:
| > Ok, thats what I thought.
| > Another question. Should I expect the igeom test codes in
| > itaps/igeom,
| > like testSmooth, to be able to read bricks.stp? I am getting segv's
| > with
| > it whereas it is reading the default .h5m file ok I guess.
igeom test codes in moab/itaps/igeom will work with moab h5m files only, they are using moab igeom implementation. It is my fault that it is not bailing out more gracefully if the files are not h5m. Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120530/8b886cea/attachment.html>
