[MOAB-dev] Fwd: question about reduce_tags behavior
Tim Tautges
tautges at mcs.anl.gov
Thu May 10 12:36:43 CDT 2012
On 05/04/2012 11:27 AM, Lorenzo Alessio Botti wrote:
> I don't know if it's a bug or if I initially misunderstood the behavior of reduce_tags
> Know it works as follows
> pcomm->reduce_tags(gid_tag_vec, gid_tag_vec, MPI_SUM, sharedFaces);
> provides in gid_tag_vec the sum of the tag values on shared faces, so it sums the value of the tag on the owned and on
> the not_owned entity. This is what I need in my code.
> pcomm->reduce_tags(gid_tag_vec, gid_sum_tag_vec, MPI_OP_NULL, sharedFaces);
> provides in gid_sum_tag_vec the values of gid_tag_vec on the owned ents, so this call replicates the behavior of
> exchange_tags
> pcomm->reduce_tags(gid_tag_vec, gid_sum_tag_vec, MPI_SUM, sharedFaces);
> provides in gid_sum_tag_vec the sum of the gid_tag on the owned entity and the gid_sum_tag on the actual process
> (independently of the pstatus)
This should be fixed now, in R5514. In an unusual burst of discipline, I also added a test case for it (made debugging
easier, besides just being A Good Idea). Lemme know if it doesn't appear fixed for you, and thanks for the bug report.
- tim
> Is this the expected behavior?
> Thanks
> Lorenzo
>> On May 4, 2012, at 5:46 PM, Tautges wrote:
>>> If I read your message right, it's a bug with when you want the result in a different tag? Will fix this soon, should
>>> be easy.
>>> On your msg about mbzoltan, the fix is much appreciated, we'll definitely get that in the code base. Dont know yet
>>> about the option string, haven't looked at code yet.
>>> - tim
>>> (Sent from an Androd that dosnt autocorect as wel as an ipone)
>>> -------- Original message --------
>>> Subject: Re: question about reduce_tags behavior
>>> From: Lorenzo Alessio Botti <ihabiamx at yahoo.it <mailto:ihabiamx at yahoo.it>>
>>> To: Tim Tautges <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>>,MOAB-dev at mcs.anl.gov <mailto:MOAB-dev at mcs.anl.gov>
>>> CC:
>>> Hi Tim,
>>> I've found the bug in my code...
>>> To get the sum of a tag on shared entities I need to call
>>> and not
>>> Here is the new version, now it works...
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
