[MOAB-dev] Why I owe Iulian a beer (was: r5489 - in MOAB/trunk: doc src/io tools/mbcoupler)
Tim Tautges
tautges at mcs.anl.gov
Sun Apr 22 21:15:05 CDT 2012
That's what I get for making quick changes. I'd removed a dependency on ReadParallel from mbcoupler_test, since
currently ReadParallel isn't part of the officially-installed API. Trouble is, specifying read through ReadParallel was
how we were associating each of the source/target meshes with the proper ParallelComm. Taking out ReadParallel resulted
in both meshes being associated with the base instance, leaving nothing in the sets to couple. Or something like that.
Iulian had pointed out that mbcoupler_test wasn't really doing anything about 4 days ago, but I figured it was him not
running the problem correctly. That'll teach me.
Iulian, mbcoupler_test now works as advertised; run with:
mpiexec -np 2 ./mbparallelcomm_test
and it should produce output that looks like:
tautges at tautges-e4300:~/code/MOABpar/tools/mbcoupler$ mpiexec -np 2 ./mbcoupler_test
Mesh files not entered; using default files ../../../MOABclean/MeshFiles/unittest/64bricks_1khex.h5m and
../../../MOABclean/MeshFiles/unittest/64bricks_12ktet.h5m
Interpolation field name not given, using default of vertex_field
No arguments given; using output file dum.h5m.
Parallel Read times:
0.109114 PARALLEL READ PART
0.0858841 PARALLEL RESOLVE_SHARED_ENTS
0.0298569 PARALLEL EXCHANGE_GHOSTS
0.00246406 PARALLEL RESOLVE_SHARED_SETS
0.225054 PARALLEL TOTAL
Proc 0 iface entities:
Proc 446 0d iface entities.
1080 1d iface entities.
636 2d iface entities.
0 3d iface entities.
(446 verts adj to other iface ents)
0.190977 PARALLEL READ PART
0.145103 PARALLEL RESOLVE_SHARED_ENTS
0.131522 PARALLEL EXCHANGE_GHOSTS
0.00399399 PARALLEL RESOLVE_SHARED_SETS
0.469953 PARALLEL TOTAL
1 iface entities:
Proc 1: box min/max, tree depth = (-0.5,-0.5,-0.5), (3.5,1.5,3.5), 12
Proc 0: box min/max, tree depth = (-0.5,1.5,-0.5), (3.5,3.5,3.5), 12
point location: wanted 1096 got 1019 locally, 77 remote, missing 0
point location: wanted 1376 got 1193 locally, 183 remote, missing 0
Max time : 2.26571 0.067872 0.00307703 (inst loc interp -- 2 procs )
Wrote dum.h5m
mbcoupler_test complete.
WriteHDF5: 0.175747
gather mesh: 0.046762
create file: 0.108039
create nodes: 0.02457
negotiate types: 7.39098e-05
craete elem: 0.00078702
file id exch: 0.0388541
create adj: 0.0100751
create set: 0.00707388
shared ids: 2.40803e-05
shared data: 5.19753e-05
set offsets: 0.00692511
create tags: 0.032994
coordinates: 0.000541925
connectivity: 0.017906
sets: 0.00828004
set descrip: 0.000555992
set content: 0.006037
set parent: 0.000854969
set child: 0.000818014
adjacencies: 1.97887e-05
tags: 0.017417
dense data: 0.00207114
sparse data: 0.015233
var-len data: 0
Wrote dum.h5m
- tim
-------- Original Message --------
Subject: [MOAB-dev] r5489 - in MOAB/trunk: doc src/io tools/mbcoupler
Date: Sun, 22 Apr 2012 21:09:47 -0500 (CDT)
Reply-To: moab-dev at mcs.anl.gov
Author: tautges
Date: 2012-04-22 21:09:46 -0500 (Sun, 22 Apr 2012)
New Revision: 5489
Modified:
MOAB/trunk/doc/metadata_info.doc
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/src/io/Tqdcfr.cpp
MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
Fixing bug I'd introduced the last time I touched mbcoupler_test. Iulian,
I owe you a beer.
Changed the name of the tag used to indicate reverse-sense faces in neumann
sets, from SENSE to NEUSET_SENSE; updated metadata_info document accordingly.
Modified: MOAB/trunk/doc/metadata_info.doc
(Binary files differ)
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -1052,7 +1052,7 @@
// set the reverse tag
Tag sense_tag;
int dum_sense = 0;
- result = mdbImpl->tag_get_handle("SENSE", 1, MB_TYPE_INTEGER, sense_tag,
+ result = mdbImpl->tag_get_handle("NEUSET_SENSE", 1, MB_TYPE_INTEGER, sense_tag,
MB_TAG_SPARSE|MB_TAG_CREAT, &dum_sense);
if (result != MB_SUCCESS) return result;
dum_sense = -1;
Modified: MOAB/trunk/src/io/Tqdcfr.cpp
--- MOAB/trunk/src/io/Tqdcfr.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/src/io/Tqdcfr.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -742,7 +742,7 @@
if (tmp_result != MB_SUCCESS) result = tmp_result;
int def_val = 1;
Tag sense_tag;
- tmp_result = mdbImpl->tag_get_handle("SENSE", 1, MB_TYPE_INTEGER, sense_tag,
+ tmp_result = mdbImpl->tag_get_handle("NEUSET_SENSE", 1, MB_TYPE_INTEGER, sense_tag,
MB_TAG_SPARSE|MB_TAG_CREAT, &def_val);
def_val = -1;
@@ -800,7 +800,7 @@
int def_val = 1;
Tag sense_tag;
if (tmp_result != MB_SUCCESS && tmp_result != MB_ALREADY_ALLOCATED) result = tmp_result;
def_val = -1;
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -1,6 +1,8 @@
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "moab/Core.hpp"
+#include "FileOptions.hpp"
+#include "ReadParallel.hpp"
