[MOAB-dev] r5489 - in MOAB/trunk: doc src/io tools/mbcoupler
tautges at mcs.anl.gov
Sun Apr 22 21:09:47 CDT 2012
Author: tautges
Date: 2012-04-22 21:09:46 -0500 (Sun, 22 Apr 2012)
New Revision: 5489
Modified:
MOAB/trunk/doc/metadata_info.doc
MOAB/trunk/src/io/ReadNCDF.cpp
MOAB/trunk/src/io/Tqdcfr.cpp
MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
Fixing bug I'd introduced the last time I touched mbcoupler_test. Iulian,
I owe you a beer.
Changed the name of the tag used to indicate reverse-sense faces in neumann
sets, from SENSE to NEUSET_SENSE; updated metadata_info document accordingly.
Modified: MOAB/trunk/doc/metadata_info.doc
(Binary files differ)
Modified: MOAB/trunk/src/io/ReadNCDF.cpp
--- MOAB/trunk/src/io/ReadNCDF.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/src/io/ReadNCDF.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -1052,7 +1052,7 @@
// set the reverse tag
Tag sense_tag;
int dum_sense = 0;
- result = mdbImpl->tag_get_handle("SENSE", 1, MB_TYPE_INTEGER, sense_tag,
+ result = mdbImpl->tag_get_handle("NEUSET_SENSE", 1, MB_TYPE_INTEGER, sense_tag,
MB_TAG_SPARSE|MB_TAG_CREAT, &dum_sense);
if (result != MB_SUCCESS) return result;
dum_sense = -1;
Modified: MOAB/trunk/src/io/Tqdcfr.cpp
--- MOAB/trunk/src/io/Tqdcfr.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/src/io/Tqdcfr.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -742,7 +742,7 @@
if (tmp_result != MB_SUCCESS) result = tmp_result;
int def_val = 1;
Tag sense_tag;
- tmp_result = mdbImpl->tag_get_handle("SENSE", 1, MB_TYPE_INTEGER, sense_tag,
+ tmp_result = mdbImpl->tag_get_handle("NEUSET_SENSE", 1, MB_TYPE_INTEGER, sense_tag,
MB_TAG_SPARSE|MB_TAG_CREAT, &def_val);
def_val = -1;
@@ -800,7 +800,7 @@
int def_val = 1;
Tag sense_tag;
if (tmp_result != MB_SUCCESS && tmp_result != MB_ALREADY_ALLOCATED) result = tmp_result;
def_val = -1;
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2012-04-22 13:31:40 UTC (rev 5488)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp 2012-04-23 02:09:46 UTC (rev 5489)
@@ -1,6 +1,8 @@
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "moab/Core.hpp"
+#include "FileOptions.hpp"
+#include "ReadParallel.hpp"
