[MOAB-dev] Backporting to version 4.5
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Mar 28 12:59:55 CDT 2012
What I really should have done was add this to the 4.5 branch, rather than the tagged code.  I'll back out that change
and put it in the branch where it belongs.
The reason we can't simply add from the trunk is that not all the update points in the trunk will be backported, so a
given file might not be directly compatible.
- tim
On 03/28/2012 12:52 PM, Steve Jackson wrote:
> Philosophy question: shouldn't the tags/4.5 tag code be permanent and fixed, with all fixes created in trunk and released periodically (and tagged) as 4.5.X?  I think that would be more in keeping with subversion best practice.  It seems to me that changing the code in the tag defeats the purpose of the tag-- i.e. having a fixed version so we can refer to "version 4.5.0" instead of "version 4.5 at r5000."
> ~S
> (Duplicating reply to mailing list this time.)
> On Mar 28, 2012, at 11:17 , Tim Tautges wrote:
>> Hi all,
>>   As you may have seen, I just backported a fix to MOAB version 4.5.  For the next few months, I'd like everyone to continue backporting important fixes to 4.5.  I'll start pointing applications to use 4.5, esp ones that aren't dependent on lots of concurrent MOAB development.  On the MCS LAN, I'll also periodically update the /home/fathom/libs/MOAB-4.5-... directories as needed, which hold builds for the various compiler/configuration options (pgi/intel, serial/parallel).  For gcc, you should use the intel version.  If you're not sure whether something is important enough to backport, please ask.
>> Thanks.
>> - tim
>> "You will keep in perfect peace him whose mind is
>>   steadfast, because he trusts in you."               Isaiah 26:3
>>              Tim Tautges            Argonne National Laboratory
>>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>>             fax: (608) 263-4499      Madison, WI 53706
