[MOAB-dev] Backporting to version 4.5
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Mar 28 11:17:03 CDT 2012
Hi all,
   As you may have seen, I just backported a fix to MOAB version 4.5.  For the next few months, I'd like everyone to
continue backporting important fixes to 4.5.  I'll start pointing applications to use 4.5, esp ones that aren't
dependent on lots of concurrent MOAB development.  On the MCS LAN, I'll also periodically update the
/home/fathom/libs/MOAB-4.5-... directories as needed, which hold builds for the various compiler/configuration options
(pgi/intel, serial/parallel).  For gcc, you should use the intel version.  If you're not sure whether something is
important enough to backport, please ask.
Thanks.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
