[MOAB-dev] r5427 - MOAB/trunk/src/io
    iulian at mcs.anl.gov
    Tue Mar 13 14:33:07 CDT 2012
Author: iulian
Date: 2012-03-13 14:33:07 -0500 (Tue, 13 Mar 2012)
New Revision: 5427
Modified:
   MOAB/trunk/src/io/Tqdcfr.cpp
Log:
read the id and uid from a cubit file with composite geometry
a simple file with composite curves is processed fine
Modified: MOAB/trunk/src/io/Tqdcfr.cpp
--- MOAB/trunk/src/io/Tqdcfr.cpp	2012-03-13 15:51:30 UTC (rev 5426)
+++ MOAB/trunk/src/io/Tqdcfr.cpp	2012-03-13 19:33:07 UTC (rev 5427)
@@ -2346,6 +2346,21 @@
       num_read = sscanf(records[current_attrib].att_string.c_str(), "UNIQUE_ID 1 0 1 %d", &uid);
       if (1 != num_read) return MB_FAILURE;
+    else if (strncmp(records[current_attrib].att_string.c_str(), "COMPOSITE_ATTRIB @9 UNIQUE_ID", 29) == 0) {
+        // parse uid
+      int dum1, dum2, dum3, dum4;
+      num_read = sscanf(records[current_attrib].att_string.c_str(), "COMPOSITE_ATTRIB @9 UNIQUE_ID %d %d %d %d %d",
+          &dum1, &dum2, &dum3, &dum4, &uid);
+      if (5 != num_read) return MB_FAILURE;
+    else if (strncmp(records[current_attrib].att_string.c_str(), "COMPOSITE_ATTRIB @9 ENTITY_ID", 29) == 0) {
+        // parse id
+      int dum1, dum2, dum3;
+      num_read = sscanf(records[current_attrib].att_string.c_str(), "COMPOSITE_ATTRIB @9 ENTITY_ID %d %d %d %d",
+          &dum1, &dum2, &dum3, &id);
+      if (4 != num_read) return MB_FAILURE;
     else {
       attrib_vec.push_back(records[current_attrib].att_string);
