[MOAB-dev] r5426 - in MOAB/trunk/src/parallel: . moab
    tautges at mcs.anl.gov
    Tue Mar 13 10:51:31 CDT 2012
Author: tautges
Date: 2012-03-13 10:51:30 -0500 (Tue, 13 Mar 2012)
New Revision: 5426
Modified:
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
Adding some variants of tags_reduce.  Unit tests are coming along, but
not mature enough to commit yet.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2012-03-12 21:54:17 UTC (rev 5425)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2012-03-13 15:51:30 UTC (rev 5426)
@@ -7032,6 +7032,8 @@
     DataType tags_type, tagd_type;
     std::vector<unsigned char> vals;
     for (vits = src_tags.begin(), vitd = dst_tags.begin(); vits != src_tags.end(); vits++, vitd++) {
+      if (*vits == *vitd) continue;
       result = mbImpl->tag_get_bytes(*vits, tags_size);
       RRA("Coudln't get src tag bytes.");
       result = mbImpl->tag_get_bytes(*vitd, tagd_size);
@@ -7142,18 +7144,6 @@
-      // set default values for dst_tags on entities
-    int tag_size;
-    for (vits = src_tags.begin(), vitd = dst_tags.begin(); vits != src_tags.end(); vits++, vitd++) {
-      result = mbImpl->tag_get_bytes(*vits, tag_size);
-      RRA("Couldn't get tag bytes.");
-      vals.resize(tag_size);
-      result = mbImpl->tag_get_default_value(*vits, &vals[0]);
-      RRA("Couldn't get default value.");
-      result = mbImpl->tag_clear_data(*vitd, entities, &vals[0]);
-      RRA("Couldn't reset tag data.");
     // receive/unpack tags
     while (incoming) {
       MPI_Status status;
@@ -7171,13 +7161,10 @@
       bool done = false;
       std::vector<EntityHandle> dum_vec;
-      result = recv_buffer(MB_MESG_TAGS_SIZE,
-			   status,
-			   remoteOwnedBuffs[ind/2],
-			   recv_tag_reqs[ind/2 * 2], recv_tag_reqs[ind/2 * 2 + 1],
-			   incoming,
-			   localOwnedBuffs[ind/2], sendReqs[ind/2*2], sendReqs[ind/2*2+1],
-			   done);
+      result = recv_buffer(MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind/2],
+                           recv_tag_reqs[ind/2 * 2], recv_tag_reqs[ind/2 * 2 + 1],
+                           incoming, localOwnedBuffs[ind/2], sendReqs[ind/2*2], sendReqs[ind/2*2+1],
+                           done);
       RRA("Failed to resize recv buffer.");
       if (done) {
 	remoteOwnedBuffs[ind/2]->reset_ptr(sizeof(int));
