[MOAB-dev] Parallel iZoltan file for MOAB?
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue Jan 24 17:14:26 CST 2012
Actually, trying to launch it in parallel results in an error for me. Hmmm..., maybe something changed in the meantime, I "think" it used to work. Anybody has any idea if this is supposed to work like that or not? mpiexec -np 2 mbpart 8 ../../MeshFiles/unittest/PB.h5m oop.h5m MBZoltan::partition_mesh_geom must be called in serial. Partitioner failed! Error code: MB_FAILURE (MBZoltan::partition_mesh_geom must be called in serial. Partitioner failed! 16) Error message: No tag value for root set Error code: MB_FAILURE (16) Error message: No tag value for root set rank 1 in job 2 iulian-desktop_53569 caused collective abort of all ranks exit status of rank 1: return code 3 Maybe this is why the iMeshP zoltan test is failing. How is this built, launched? Iulian ----- Original Message -----
| I usually do a partitioning in serial, with something like
| ./tools/mbzoltan/mbpart 8 MeshFiles/unittest/PB.h5m out.h5m
| 8 is the number of partitions
| How is this test launched?
| Our README file in tools/mbzoltan says that it should be launched in
| parallel, but it works in serial (too).
| The file out.h5m will have PARALLEL_PARTITION sets tagged, that can be
| viewed in visit, as in the file attached
| Iulian
| | At the ITAPS telecon last week, we discussed the weekly test results
| | (as
| | usual). One thing that came up was the parallel iZoltan tests, which
| | we're currently failing[1]. We think the issue is that we need a
| | file
| | which MOAB can understand. Any ideas on the file we should be using
| | for
| | this?
| | - Jim
| | [1]
| | https://itaps.mcs.anl.gov/resultsp.20120118/IZOLTANP_MOAB.results
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120124/44c5d4b9/attachment.htm>
