[MOAB-dev] Parallel iZoltan file for MOAB?
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue Jan 24 16:59:56 CST 2012
I usually do a partitioning in serial, with something like ./tools/mbzoltan/mbpart 8 MeshFiles/unittest/PB.h5m out.h5m 8 is the number of partitions How is this test launched? Our README file in tools/mbzoltan says that it should be launched in parallel, but it works in serial (too). The file out.h5m will have PARALLEL_PARTITION sets tagged, that can be viewed in visit, as in the file attached Iulian ----- Original Message -----
| At the ITAPS telecon last week, we discussed the weekly test results
| (as
| usual). One thing that came up was the parallel iZoltan tests, which
| we're currently failing[1]. We think the issue is that we need a file
| which MOAB can understand. Any ideas on the file we should be using
| for
| this?
| - Jim
| [1] https://itaps.mcs.anl.gov/resultsp.20120118/IZOLTANP_MOAB.results
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120124/14b586fb/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20120124/14b586fb/attachment-0001.png>
