[MOAB-dev] r5286 - in MOAB/trunk/src: . io
    jvporter at wisc.edu
    Thu Jan  5 13:10:16 CST 2012
Author: jvporter
Date: 2012-01-05 13:10:16 -0600 (Thu, 05 Jan 2012)
New Revision: 5286
Modified:
   MOAB/trunk/src/SetIterator.cpp
   MOAB/trunk/src/SmoothCurve.cpp
   MOAB/trunk/src/SparseTag.cpp
   MOAB/trunk/src/WriteUtil.cpp
   MOAB/trunk/src/io/ReadNC.cpp
Log:
Eliminate some warnings
Modified: MOAB/trunk/src/SetIterator.cpp
--- MOAB/trunk/src/SetIterator.cpp	2012-01-05 18:16:12 UTC (rev 5285)
+++ MOAB/trunk/src/SetIterator.cpp	2012-01-05 19:10:16 UTC (rev 5286)
@@ -27,6 +27,9 @@
       // special case for the root set, have to keep a local array
     ErrorCode rval = build_pair_vec();
     assert(MB_SUCCESS == rval);
+      // empty statement to avoid warning
+    (void)(rval);
Modified: MOAB/trunk/src/SmoothCurve.cpp
--- MOAB/trunk/src/SmoothCurve.cpp	2012-01-05 18:16:12 UTC (rev 5285)
+++ MOAB/trunk/src/SmoothCurve.cpp	2012-01-05 19:10:16 UTC (rev 5286)
@@ -202,7 +202,7 @@
   // find the closest node, then find the closest edge, based on closest node
-  int indexNode;
+  int indexNode = 0;
   double minDist = 1.e30;
   // expensive linear search
   for (int i=0; i<numNodes; i++)
Modified: MOAB/trunk/src/SparseTag.cpp
--- MOAB/trunk/src/SparseTag.cpp	2012-01-05 18:16:12 UTC (rev 5285)
+++ MOAB/trunk/src/SparseTag.cpp	2012-01-05 19:10:16 UTC (rev 5286)
@@ -354,7 +354,7 @@
     return rval;
     // get pointer to tag storage for entity pointed to by iter
-  const void* ptr;
+  const void* ptr = NULL;
   rval = get_data_ptr( 0, *iter, ptr );
   if (MB_SUCCESS == rval)
     data_ptr = const_cast<void*>(ptr);
Modified: MOAB/trunk/src/WriteUtil.cpp
--- MOAB/trunk/src/WriteUtil.cpp	2012-01-05 18:16:12 UTC (rev 5285)
+++ MOAB/trunk/src/WriteUtil.cpp	2012-01-05 19:10:16 UTC (rev 5286)
@@ -921,7 +921,7 @@
   SequenceManager *sm = mMB->sequence_manager();
   const EntitySequence *tmp_seq;
