[MOAB-dev] r5284 - MOAB/trunk/itaps
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Jan 4 09:12:50 CST 2012
Author: tautges
Date: 2012-01-04 09:12:44 -0600 (Wed, 04 Jan 2012)
New Revision: 5284
Removed:
   MOAB/trunk/itaps/iBase_f.h
Log:
Removing, since it's now auto-generated.  Thanks Iulian.
Deleted: MOAB/trunk/itaps/iBase_f.h
--- MOAB/trunk/itaps/iBase_f.h	2011-12-29 16:40:59 UTC (rev 5283)
+++ MOAB/trunk/itaps/iBase_f.h	2012-01-04 15:12:44 UTC (rev 5284)
@@ -1,141 +0,0 @@
-#ifndef IBASE_F_H
-#define IBASE_F_H
-#ifdef POINTER_SIZE
-!  user-defined override
-#  define IBASE_HANDLE_T INTEGER*POINTER_SIZE
-#elif defined(__SIZEOF_SIZE_T__)
-!  gfortran
-#  define IBASE_HANDLE_T integer*__SIZEOF_SIZE_T__
-#elif defined(__GNUC__) && defined (_LANGUAGE_FORTRAN)
-!  gfortran 4.2 and earlier
-#  ifdef _LP64
-#    define IBASE_HANDLE_T integer*8
-#  else
-!    NOTE: not integer*4 (see meaning of _LP64 in GNU docs)
-#  endif
-#elif defined(__INTEL_COMPILER)
-#  ifdef __X86_64
-#  else
-#    define IBASE_HANDLE_T integer*4
-#  endif
-#elif defined(__XLCPP__) || defined(__bgp__) || defined(__bgq__)
-!  __XLCPP__ doesn't work for IBM.  AT least make things work for BGP and BGQ
-        USE, INTRINSIC :: ISO_C_BINDING
-#  define IBASE_HANDLE_T C_PTR
-#else
-#  error "Unknown compiler.  Please define POINTER_SIZE."
-#endif
-#define iBase_EntityHandle IBASE_HANDLE_T
-#define iBase_EntitySetHandle IBASE_HANDLE_T
-#define iBase_TagHandle IBASE_HANDLE_T
-#endif
-      integer iBase_VERTEX
-      integer iBase_EDGE
-      integer iBase_FACE
-      integer iBase_REGION
-      integer iBase_ALL_TYPES
-      parameter (iBase_VERTEX = 0)
-      parameter (iBase_EDGE = 1)
-      parameter (iBase_FACE = 2)
