[MOAB-dev] r5261 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov
Wed Dec 14 00:36:18 CST 2011
Author: iulian
Date: 2011-12-14 00:36:12 -0600 (Wed, 14 Dec 2011)
New Revision: 5261
Added:
MOAB/trunk/itaps/igeom/testSmooth2.cc
Modified:
MOAB/trunk/itaps/igeom/FBiGeom.h
MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp
MOAB/trunk/itaps/igeom/FBiGeom_MOAB.hpp
MOAB/trunk/itaps/igeom/Makefile.am
Log:
an example of the new FBiGeom instantiation, that will take as input an
iMesh instance (moab) and a "model root" set
this function is a special brand, it makes a direct connection between
iMesh and iGeom; right now, it can't be easily declared
in FBiGeom.h, because it has the iMesh_Instance as input parameter.
The implementation of this new function (FBiGeom_newGeomFromMesh) is in
FBiGeom_MOAB.cpp, but its declaration should be maybe somewhere else
(for the example to run, I just declared it extern in the test itself :( )
Modified: MOAB/trunk/itaps/igeom/FBiGeom.h
--- MOAB/trunk/itaps/igeom/FBiGeom.h 2011-12-13 15:38:07 UTC (rev 5260)
+++ MOAB/trunk/itaps/igeom/FBiGeom.h 2011-12-14 06:36:12 UTC (rev 5261)
@@ -59,6 +59,7 @@
#include "iBase.h"
#include "FBiGeom_protos.h"
+//#include "iMesh.h"
#ifdef __cplusplus
extern "C" {
#endif
@@ -104,6 +105,21 @@
int* err,
int options_len );
+ /**\brief Construct a new FBiGeom instance
+ * Construct a new FBiGeom instance, using an existing moab iMesh instance
+ * and a root set that encapsulates the topological model
+ * \param mesh iMesh_Instance
+ * \param set root set for the mesh based geometry
+ * \param options Pointer to implementation-specific options string
+ * \param instance Pointer to FBiGeom instance handle returned from function
+ * \param *err Pointer to error type returned from function
+ * \param options_len Length of the character string pointed to by options
+/* void FBiGeom_newGeomFromMesh( iMesh_Instance mesh, iBase_EntitySetHandle set,
+ const char *options, FBiGeom_Instance *geom,
+ int *err, int options_len);*/
/**\brief Destroy an FBiGeom instance
* Destroy an FBiGeom instance
Modified: MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp
--- MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp 2011-12-13 15:38:07 UTC (rev 5260)
+++ MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp 2011-12-14 06:36:12 UTC (rev 5261)
@@ -75,6 +75,29 @@
*err = iBase_SUCCESS;
+void FBiGeom_newGeomFromMesh(iMesh_Instance mesh, iBase_EntitySetHandle set,
+ MBiMesh * mbimesh = reinterpret_cast<MBiMesh *>(mesh);
+ moab::Interface * mbi = mbimesh->mbImpl;
+ moab::EntityHandle rootSet = reinterpret_cast<moab::EntityHandle> (set);
+ moab::GeomTopoTool * gtt = new moab::GeomTopoTool(mbi, true, rootSet);
