[MOAB-dev] r5259 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov
Mon Dec 12 16:58:51 CST 2011
Author: iulian
Date: 2011-12-12 16:58:49 -0600 (Mon, 12 Dec 2011)
New Revision: 5259
Modified:
MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp
Log:
add the missing methods (not implemented yet)
With this change, FBiGeom.hpp in MeshKit can be very similar to iGeom.hpp
Modified: MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp
--- MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp 2011-12-12 20:16:34 UTC (rev 5258)
+++ MOAB/trunk/itaps/igeom/FBiGeom_MOAB.cpp 2011-12-12 22:58:49 UTC (rev 5259)
@@ -1064,12 +1064,6 @@
int* err) {
-void FBiGeom_getArrTolerance(FBiGeom_Instance,
- iBase_EntityHandle const* entity_handles, int entity_handles_size,
- double** tolerances, int* tolerances_allocated, int* tolerances_size,
- int* err) {
void FBiGeom_initEntIter(FBiGeom_Instance, iBase_EntitySetHandle entity_set_handle,
int entity_dimension, iBase_EntityIterator* entity_iterator, int* err) {
@@ -1645,4 +1639,204 @@
iBase_EntitySetHandle* result_entity_set, int *err) {
+// TODO methods not yet implemented
+void FBiGeom_getEntClosestPtTrimmed( FBiGeom_Instance instance,
+ iBase_EntityHandle entity_handle,
+ double near_x,
+ double near_y,
+ double near_z,
+ double* on_x,
+ double* on_y,
+ double* on_z,
+ int* err )
+ RETURN(iBase_FAILURE);
+void FBiGeom_getFcCvtrXYZ( FBiGeom_Instance instance,
+ iBase_EntityHandle face_handle,
+ double x,
+ double y,
+ double z,
+ double* cvtr1_i,
+ double* cvtr1_j,
+ double* cvtr1_k,
+ double* cvtr2_i,
+ double* cvtr2_j,
+ double* cvtr2_k,
+ int* err )
