[MOAB-dev] r5246 - MOAB/trunk/test
jvporter at wisc.edu jvporter at wisc.edu
Thu Dec 8 14:00:09 CST 2011
Author: jvporter
Date: 2011-12-08 14:00:09 -0600 (Thu, 08 Dec 2011)
New Revision: 5246
Modified:
   MOAB/trunk/test/TagTest.cpp
Log:
Eliminate some warnings
Modified: MOAB/trunk/test/TagTest.cpp
--- MOAB/trunk/test/TagTest.cpp	2011-12-08 19:40:25 UTC (rev 5245)
+++ MOAB/trunk/test/TagTest.cpp	2011-12-08 20:00:09 UTC (rev 5246)
@@ -187,7 +187,7 @@
   int bytes;
   rval = mb.tag_get_bytes( tag, bytes );
   CHECK_ERR(rval);
-  int exp_bytes;
+  int exp_bytes = 0;
   switch (type) {
     case MB_TYPE_INTEGER: exp_bytes = num_vals * sizeof(int); break;
     case MB_TYPE_DOUBLE: exp_bytes = num_vals * sizeof(double); break;
@@ -375,7 +375,7 @@
   CHECK_ERR(rval);
   CHECK( !entities.empty() );
-  int bytes;
+  int bytes = 0;
   switch (type) {
     case MB_TYPE_INTEGER: bytes = vals_per_ent*sizeof(int); break;
     case MB_TYPE_DOUBLE : bytes = vals_per_ent*sizeof(double); break;
@@ -1553,7 +1553,7 @@
   CHECK_EQUAL( lengths[0], data_len );
   CHECK( !memcmp( values[0], data_ptr, data_len ) );
-  int typesize;
+  int typesize = 0;
   switch (type) {
     case MB_TYPE_INTEGER: typesize = sizeof(int); break;
     case MB_TYPE_DOUBLE:  typesize = sizeof(double); break;
