[MOAB-dev] r5195 - MOAB/trunk/src/parallel
jain at mcs.anl.gov
jain at mcs.anl.gov
Tue Oct 18 20:33:03 CDT 2011
Author: jain
Date: 2011-10-18 20:33:03 -0500 (Tue, 18 Oct 2011)
New Revision: 5195
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
o Fix bug for in communicate shared sets when non-blocking recv for small buffer consumes the data for large buffers.
o Added a new variable lrecv_req for large buffer.
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-10-13 21:56:23 UTC (rev 5194)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2011-10-19 01:33:03 UTC (rev 5195)
@@ -1836,7 +1836,9 @@
// post receive buffers for all owned sets for all sharing procs
- std::vector<MPI_Request> recv_req(numrecv);
+ std::vector<MPI_Request> recv_req(numrecv, MPI_REQUEST_NULL);
+ std::vector<MPI_Request> lrecv_req(numrecv, MPI_REQUEST_NULL);
std::vector< std::vector<unsigned long> > recv_buf(numrecv,std::vector<unsigned long>(init_buff_size));
int idx = 0;
for (Range::iterator i = owned.begin(); i != owned.end(); ++i) {
@@ -1952,7 +1954,6 @@
rval = unpack_set( handle, &buff[0], init_buff_size );
CHECK_MB(rval);
dead.swap(buff); // release memory
- recv_req[idx] = MPI_REQUEST_NULL;
else {
// data was too big for init_buff_size
@@ -1961,11 +1962,11 @@
dbgOut.printf(5,"Re-Posting buffer to receive set %d from proc %d with size %lu\n",
status.MPI_TAG, status.MPI_SOURCE, (unsigned long)size );
mperr = MPI_Irecv( &buff[0], size, MPI_UNSIGNED_LONG, status.MPI_SOURCE,
- status.MPI_TAG, comm, &recv_req[idx] );
+ status.MPI_TAG, comm, &lrecv_req[idx] );
CHECK_MPI(mperr);
++numrecv;
- //recv_req[idx] = MPI_REQUEST_NULL;
+ recv_req[idx] = MPI_REQUEST_NULL;
@@ -2000,7 +2001,7 @@
while (remaining--) {
std::vector<unsigned long> dead;
MPI_Status status;
- mperr = MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status );
+ mperr = MPI_Waitany( lrecv_req.size(), &lrecv_req[0], &idx, &status );
CHECK_MPI(mperr);
EntityHandle handle = CREATE_HANDLE( MBENTITYSET, status.MPI_TAG );
std::vector<unsigned long>& buff = recv_buf[idx];
@@ -2010,7 +2011,7 @@
CHECK_MB(rval);
