[MOAB-dev] moab-announce Digest, Vol 5, Issue 2
Hong-Jun Kim hongjun at mcs.anl.gov
Thu Oct 13 13:47:06 CDT 2011
I am checking it, before that, are you using a parallel build of the HDF5 library?
Thanks.
Hong-Jun
----- Original Message -----
> From: "Tiantian Xu" <tiantianxu.88 at gmail.com>
> To: "Hong-Jun Kim" <hongjun at mcs.anl.gov>
> Sent: Thursday, October 13, 2011 12:11:09 PM
> Subject: Re: moab-announce Digest, Vol 5, Issue 2
> Hi Hong-Jun,
> Yes, that machine is 64bit, however the Fedora installed is a 32-bit
> version, I'm not sure if this is the problem... However I have decided
> not to dig into the problem on that machine any more...
> I had reinstalled hdf5 and netcdf on a different machine, also 64 bit,
> with 64-bit Fedora. Moab "configure", "make", "make check" and "make
> install" were all successful. But the same error in parallel read
> occurred:
> [tiantian at vis-pc2 bin]$ mpiexec -np 2 ./mbconvert -O
> PARALLEL=READ_PART -O PARTITION=MATERIAL_SET -O
> PARALLEL_RESOLVE_SHARED_ENTS -O PARALLEL_GHOSTS=3.0.1 -o
> PARALLEL=WRITE_PART ./64bricks_512hex.h5m dummy.h5m
> Read "./64bricks_512hex.h5m"
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 139
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
> (signal 11)
> I'm very confused because now the "make check" works, all tests are
> passed, same error still occurs. So it is very likely that there are
> some subtle issues...
> The config and make log from the installed lib directory are attached.
> Thank you so much for the help.
> Tiantian
> On Thu, Oct 13, 2011 at 11:33 AM, Hong-Jun Kim < hongjun at mcs.anl.gov >
> wrote:
> Actually, I can not replicate the problem in my machine.
> Can you check if your machine is 64bit with "uname -m" command?
> Could anyone have any idea about the question below?
> Can "netcdf-4" disabled netcdf cause any segmentation error?
> > Also, before I built MOAB, when I was trying to build netcdf,
> > configure complained it could not find the z library, so I turned
> > off
> > "netcdf-4" feature, in other words, the netcdf library was not built
> > on top of hdf5/zlib. Could this be the problem?
> Thanks.
> Hong-Jun
> > Hi Hong-Jun,
> > I still have the same problems after chaning "LFLAGS=-static".
> > "config.log", "mbcn_test.log" and "test-suite.log" are all attached.
> > But I'm not sure what you mean by "error signs"..
> > off
> > on top of hdf5/zlib. Could this be the problem? I'm still trying to
> > fix the "can't find z lib" error with netcdf.
> > Thanks for your help!
> > Tiantian
> > On Wed, Oct 12, 2011 at 1:19 PM, Hong-Jun Kim < hongjun at mcs.anl.gov
> > wrote:
> > If you still have the same problems with Tim's suggestion as below,
> > could you please send me your "config.log" and error signs for me to
> > replicate it?
> > In addition, can you use " moab-dev at mcs.anl.gov " for this kind of
> > question?
> > "moab-announce" is for announcing new things and upgrades and looks
> > it
> > has some latencies to get mail.(I just got Tim's message which looks
> > sent yesterday)
> > Thanks.
> > Hong-Jun Kim
> > Post-doc researcher
> > MCS, Argonne National Laboratory
> > 9700 S. Cass Ave. B240/R2147
> > Argonne, IL 60439
> > 630-252-4791
> > > Hong-Jun,
> > > Can you check this out? Tiantian, we haven't seen this problem
> > > anywhere. The output from your configure looks like
> > > you're on a 64bit machine, but can you verify that? The only other
> > > thing that looks strange in your configure is the
> > > LFLAGS=-static; you should be able to get the same thing, in a
> > > more
> > > standard way, using --disable-shared
> > > --enable-static. Could you try that? Thanks.
> > > - tim
> > > On 10/11/2011 12:58 PM, Tiantian Xu wrote:
> > > > Hi,
> > > > I was trying to build moab but met with the "mbcn_test fail"
> > > > during
> > > > make
> > > > check.
> > > > The commands I used to build the library were:
> > > > ./configure LFLAGS=-static
> > > > --with-mpi=/home/tiantian/ITL/mpich2-1.4.1p1/gcc
> > > > --with-hdf5=/home/tiantian/hdf5
> > > > --with-netcdf=/home/tiantian/ITL/netcdf-4.1.3/gcc
> > > > --with-zlib=/home/tiantian/ITL/zlib-1.2.5/gcc
> > > > --with-szip=/home/tiantian/ITL/szip-2.1/gcc
> > > > --prefix=/home/tiantian/ITL/moab 2>&1 | tee configure.log
> > > > make 2>&1 | make.log
> > > > make check 2>&1 | tee make.check.log
> > > > Looks like the mbcn_test is about query on entities, I don't
> > > > know
> > > > why
> > > > this went wrong. Later I ignored the make check errors and did
> > > > "make
> > > > install". I tried to perform parallel read/write and found
> > > > mbconvert
> > > > went wrong too:
> > > > $mpiexec -np 2 ./mbconvert -O PARALLEL=READ_PART -O
> > > > PARTITION=MATERIAL_SET -O PARALLEL_RESOLVE_SHARED_ENTS -O
> > > > PARALLEL_GHOSTS=3.0.1 -o PARALLEL=WRITE_PART
> > > > dummy.h5m
> > > > = EXIT CODE: 139
> > > > (signal 11)
> > > > I suspect some fundamental functions in moab were not properly
> > > > made?
> > > > I had attached the log files. Please take a look.
> > > > Thanks a lot for your help!
> > > > Best,
> > > > Tiantian
> > > "You will keep in perfect peace him whose mind is
> > > steadfast, because he trusts in you." Isaiah 26:3
> > > Tim Tautges Argonne National Laboratory
> > > ( tautges at mcs.anl.gov ) (telecommuting from UW-Madison)
> > > phone: (608) 263-8485 1500 Engineering Dr.
> > > fax: (608) 263-4499 Madison, WI 53706
> > > _______________________________________________
> > > moab-announce mailing list
> > > moab-announce at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/moab-announce
> > > End of moab-announce Digest, Vol 5, Issue 2
