[MOAB-dev] r5193 - MOAB/trunk/src
iulian at mcs.anl.gov
Thu Oct 13 10:51:48 CDT 2011
Author: iulian
Date: 2011-10-13 10:51:48 -0500 (Thu, 13 Oct 2011)
New Revision: 5193
Modified:
MOAB/trunk/src/FBEngine.cpp
Log:
implement method createTag, which will be called by
FBiGeom::createTag in meshkit, similar to iGeom_createTag()
Modified: MOAB/trunk/src/FBEngine.cpp
--- MOAB/trunk/src/FBEngine.cpp 2011-10-13 14:43:58 UTC (rev 5192)
+++ MOAB/trunk/src/FBEngine.cpp 2011-10-13 15:51:48 UTC (rev 5193)
@@ -826,19 +826,45 @@
return MB_SUCCESS;
-/*// new methods needed
- ErrorCode FBEngine::getTagHandle( const char* name, moab::Tag & handle_out )
- return _mbImpl->tag_get_handle(name, handle_out);
+// so far, this one is
+// used only for __MKModelEntityGeo tag
-ErrorCode FBEngine::createTag(const char* /*tag_name*/, int /*tag_num_type_values*/,
- int /*tag_type*/, Tag & /*tag_handle_out*/)
+ErrorCode FBEngine::createTag(const char* tag_name, int tag_size, int tag_type,
+ Tag & tag_handle_out)
- // not implemented yet, some mapping needed for tag type
- return MB_FAILURE;
+ // this is copied from iMesh_MOAB.cpp; different name to not have trouble
+ // with it
+ // also, we do not want to depend on iMesh.h...
+ // iMesh is more complicated, because of the options passed
+ DataType mb_data_type_table2[] = { MB_TYPE_OPAQUE, MB_TYPE_INTEGER,
+ MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_HANDLE };
+ moab::TagType storage = MB_TAG_SPARSE;
+ ErrorCode result;
+ result = MBI->tag_get_handle(tag_name, tag_size,
+ mb_data_type_table2[tag_type], tag_handle_out, storage | MB_TAG_EXCL);
+ if (MB_SUCCESS != result) {
+ std::string msg("iMesh_createTag: ");
+ if (MB_ALREADY_ALLOCATED == result) {
+ msg += "Tag already exists with name: \"";
+ msg += tag_name;
+ std::cout<<msg << "\n";
+ else
+ std::cout<< "Failed to create tag with name: " << tag_name << "\n";
+ return MB_FAILURE;
