[MOAB-dev] Fwd: vertex to cell adjacencies in parallel
Lorenzo Alessio Botti
ihabiamx at yahoo.it
Sat Oct 8 10:07:55 CDT 2011
Thanks, and no rush...
Hope not to have busy your week end with a bug.
And sorry for the code, I copied and paste some
chunks to make it run independently from my application,
the result is not so pleasant.
Lorenzo
On Oct 8, 2011, at 12:21 AM, Hong-Jun Kim wrote:
> Hi, I just want to let you know I am working for this.
> Sorry for the delay and I have spent some time to understand your code.
> Even though I can not finish it today, let me do it as soon as possible.
> Thanks.
> Hong-Jun
>> From: "Lorenzo Alessio Botti" <ihabiamx at yahoo.it>
>> To: MOAB-dev at mcs.anl.gov
>> Sent: Friday, October 7, 2011 11:26:16 AM
>> Subject: [MOAB-dev] Fwd: vertex to cell adjacencies in parallel
>> I forgot to reply to the list...
>> Begin forwarded message:
>> From: Lorenzo Alessio Botti < ihabiamx at yahoo.it >
>> Subject: Re: [MOAB-dev] vertex to cell adjacencies in parallel
>> Date: October 7, 2011 5:52:49 PM GMT+02:00
>> To: Hong-Jun Kim < hongjun at mcs.anl.gov >
>> Hi Hong-Jun,
>> I attach the code you can run it as
>> mpiexec -n 2 [exe_name] -P -R
>> [path_to_one_of_the_mesh_files_here_attached]
>> Let me explain it a bit.
>> I start from a 5x5x5 hex cube with 2 partitions.
>> The cells on the interface form more or less a 5x5x1 25 hexes row.
>> (They do in the hex 27 mesh while in the hex 8 an hex is misplaced for
>> some reason)
>> 25 elements have a face on the interface, 25 elements share a face
>> with owned cells,
>> 20 elements have a face on boundary. You can take a look to the .vtk
>> output.
>> Let me comment the output
>> iface faces size 25 ok
>> ghost cells size 50 shared = 25 ok, every face on iface has two
>> neighbors one owned one not owned
>> Now the code searches the vertex adjacencies for the 25 owned cells,
>> this is the output
>> owned entities = 25 adjacent entities not found = 45 this in wrong,
>> the number of adjacencies not found should be 25 smaller, that is
>> equal to number of faces on the boundary.
>> Thanks a lot.
>> Lorenzo
>> On Oct 7, 2011, at 4:53 PM, Hong-Jun Kim wrote:
>> Could you please send me the code to replicate?
>> Thanks.
>> Hong-Jun Kim
>> Post-doc researcher
>> MCS, Argonne National Laboratory
>> 9700 S. Cass Ave. B240/R2147
>> Argonne, IL 60439
>> 630-252-4791
>> From: "Lorenzo Alessio Botti" < ihabiamx at yahoo.it >
>> To: "Tim Tautges" < tautges at mcs.anl.gov >, MOAB-dev at mcs.anl.gov
>> Sent: Friday, October 7, 2011 9:47:52 AM
>> Thanks a lot for the reply.
>> Let me know if you need the code to replicate this issue...
>> For my application it would be very interesting to be able to
>> partition based on entity sets.
>> If those entity sets form a covering for the entities (each of the
>> entities included in exactly one of those sets), and those sets can
>> be identified by a tag and optionally tag value, then you should be
>> able to already read in parallel based on that partition (which has
>> to already be in the file). See section 5 of the user's guide (in
>> the doc subdir) and the description of how to read according to a
>> material_set partition.
>> My request was a bit too cryptic...
>> I'm now reading parallel meshes generated with mbzoltan with the
>> partition tag set to PARALLEL_PARTITION.
>> It would be useful (for geometric h-multigrid, adaptivity based on
>> element agglomeration ecc...)
>> to repartition based on tagged entity sets that form a covering for
>> the entities
>> (such sets might be generated requiring a lot of partitions to the
>> partitioner)
>> instead of mesh elements.
>> A simpler trick would be to create a lot of tagged entity sets and run
>> in parallel
>> with n_processes = n_entity_set/n_entity_sets_per_process, using once
>> again the
>> entity sets as mesh elements.
>> In this context the entity set can be viewed as very general elements
>> (eg polygons).
>> In both cases the ability to get the adjacencies of entity set would
>> be also required.
>> By the way I've seen that you already have a polygonal element
>> implementation
>> but I don't know if it has been introduced with the same goal.
>> Now I'm still working on the standard element dG finite element
>> library
>> but later on it would be interesting to explore more general
>> implementations.
>> Lorenzo
>> On Oct 7, 2011, at 3:54 PM, Tim Tautges wrote:
>> On 10/07/2011 04:05 AM, Lorenzo Alessio Botti wrote:
>> Hi all,
>> I have a question about getting adjacencies in parallel.
>> After having partitioned a mesh, resolved shared entities and
>> exchanged ghost cells I fail to
>> update the mesh cell adjacencies so to include ghost cells.
>> The face to elements adjacencies are correctly updated, that is the
>> faces obtained with
>> pcomm.get_iface_entities(1,2,faces); (I'm running on 2 processors)
>> have two neighbors one owned and one non owned.
>> However the vertex to cell adjacencies do not seem to be updated to
>> include ghost cells
>> and even after
>> mb.get_entities_by_dimension(0,3,entities);
>> mb.get_adjacencies(entities, 0, true, vertexEntities,
>> Interface::UNION);
>> entities.clear();
>> mb.get_adjacencies(vertexEntities, 3, true, entities,
>> Interface::UNION);
>> I'm not able to find vertex to not owned cells adjacencies.
>> Is get_adjacencies(...,create if missing=true,...) supposed to work
>> also for non owned cells?
>> It seems that the vertex to non owned cell adjacencies are detected
>> but not created.
>> That sounds like a bug; Hong-Jun, could you look at that?
>> MOAB's parallel model is that all locally-represented entities,
>> which includes ghost and shared interface entities, should appear
>> locally as a serial mesh, with all adjacencies and other API calls
>> available.
>> Overall MOAB works fine in parallel and
>> pcomm.assign_global_ids(...) is useful.
>> Are you also planning to introduce some repartitioning
>> capabilities?
>> Yes, this year's work plan includes migrating entities for
>> repartitioning. In theory, the partitioning class in tools/mbzoltan
>> should work to compute the new partition in parallel, though I think
>> it's currently hardwired to run on one processor (on my list to get
>> rid of that restriction).
>> - tim
>> Thanks for help.
>> Lorenzo
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> ( tautges at mcs.anl.gov ) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
