[MOAB-dev] Fwd:  vertex to cell adjacencies in parallel
    Hong-Jun Kim
    hongjun at mcs.anl.gov
    Fri Oct  7 17:21:15 CDT 2011
Hi, I just want to let you know I am working for this.
Sorry for the delay and I have spent some time to understand your code.
Even though I can not finish it today, let me do it as soon as possible.
Thanks.
Hong-Jun
----- Original Message -----
> From: "Lorenzo Alessio Botti" <ihabiamx at yahoo.it>
> To: MOAB-dev at mcs.anl.gov
> Sent: Friday, October 7, 2011 11:26:16 AM
> Subject: [MOAB-dev] Fwd: vertex to cell adjacencies in parallel
> I forgot to reply to the list...
> Begin forwarded message:
> From: Lorenzo Alessio Botti < ihabiamx at yahoo.it >
> Subject: Re: [MOAB-dev] vertex to cell adjacencies in parallel
> Date: October 7, 2011 5:52:49 PM GMT+02:00
> To: Hong-Jun Kim < hongjun at mcs.anl.gov >
> Hi Hong-Jun,
> I attach the code you can run it as
> mpiexec -n 2 [exe_name] -P -R
> [path_to_one_of_the_mesh_files_here_attached]
> Let me explain it a bit.
> I start from a 5x5x5 hex cube with 2 partitions.
> The cells on the interface form more or less a 5x5x1 25 hexes row.
> (They do in the hex 27 mesh while in the hex 8 an hex is misplaced for
> some reason)
> 25 elements have a face on the interface, 25 elements share a face
> with owned cells,
> 20 elements have a face on boundary. You can take a look to the .vtk
> output.
> Let me comment the output
> iface faces size 25 ok
> ghost cells size 50 shared = 25 ok, every face on iface has two
> neighbors one owned one not owned
> Now the code searches the vertex adjacencies for the 25 owned cells,
> this is the output
> owned entities = 25 adjacent entities not found = 45 this in wrong,
> the number of adjacencies not found should be 25 smaller, that is
> equal to number of faces on the boundary.
> Thanks a lot.
> Lorenzo
> On Oct 7, 2011, at 4:53 PM, Hong-Jun Kim wrote:
> Could you please send me the code to replicate?
> Thanks.
> Hong-Jun Kim
> Post-doc researcher
> MCS, Argonne National Laboratory
> 9700 S. Cass Ave. B240/R2147
> Argonne, IL 60439
> 630-252-4791
> From: "Lorenzo Alessio Botti" < ihabiamx at yahoo.it >
> To: "Tim Tautges" < tautges at mcs.anl.gov >, MOAB-dev at mcs.anl.gov
> Sent: Friday, October 7, 2011 9:47:52 AM
> Thanks a lot for the reply.
> Let me know if you need the code to replicate this issue...
> For my application it would be very interesting to be able to
> partition based on entity sets.
> If those entity sets form a covering for the entities (each of the
> entities included in exactly one of those sets), and those sets can
> be identified by a tag and optionally tag value, then you should be
> able to already read in parallel based on that partition (which has
> to already be in the file). See section 5 of the user's guide (in
> the doc subdir) and the description of how to read according to a
> material_set partition.
> My request was a bit too cryptic...
> I'm now reading parallel meshes generated with mbzoltan with the
> partition tag set to PARALLEL_PARTITION.
> It would be useful (for geometric h-multigrid, adaptivity based on
> element agglomeration ecc...)
> to repartition based on tagged entity sets that form a covering for
> the entities
> (such sets might be generated requiring a lot of partitions to the
> partitioner)
> instead of mesh elements.
> A simpler trick would be to create a lot of tagged entity sets and run
> in parallel
> with n_processes = n_entity_set/n_entity_sets_per_process, using once
> again the
> entity sets as mesh elements.
> In this context the entity set can be viewed as very general elements
> (eg polygons).
> In both cases the ability to get the adjacencies of entity set would
> be also required.
> By the way I've seen that you already have a polygonal element
> implementation
> but I don't know if it has been introduced with the same goal.
> Now I'm still working on the standard element dG finite element
> library
> but later on it would be interesting to explore more general
> implementations.
> Lorenzo
> On Oct 7, 2011, at 3:54 PM, Tim Tautges wrote:
> On 10/07/2011 04:05 AM, Lorenzo Alessio Botti wrote:
> Hi all,
> I have a question about getting adjacencies in parallel.
> After having partitioned a mesh, resolved shared entities and
> exchanged ghost cells I fail to
> update the mesh cell adjacencies so to include ghost cells.
> The face to elements adjacencies are correctly updated, that is the
> faces obtained with
> pcomm.get_iface_entities(1,2,faces); (I'm running on 2 processors)
> have two neighbors one owned and one non owned.
> However the vertex to cell adjacencies do not seem to be updated to
> include ghost cells
> and even after
> mb.get_entities_by_dimension(0,3,entities);
> mb.get_adjacencies(entities, 0, true, vertexEntities,
> Interface::UNION);
> entities.clear();
> mb.get_adjacencies(vertexEntities, 3, true, entities,
> Interface::UNION);
> I'm not able to find vertex to not owned cells adjacencies.
> Is get_adjacencies(...,create if missing=true,...) supposed to work
> also for non owned cells?
> It seems that the vertex to non owned cell adjacencies are detected
> but not created.
> That sounds like a bug; Hong-Jun, could you look at that?
> MOAB's parallel model is that all locally-represented entities,
> which includes ghost and shared interface entities, should appear
> locally as a serial mesh, with all adjacencies and other API calls
> available.
> Overall MOAB works fine in parallel and
> pcomm.assign_global_ids(...) is useful.
> Are you also planning to introduce some repartitioning
> capabilities?
> Yes, this year's work plan includes migrating entities for
> repartitioning. In theory, the partitioning class in tools/mbzoltan
> should work to compute the new partition in parallel, though I think
> it's currently hardwired to run on one processor (on my list to get
> rid of that restriction).
> - tim
> Thanks for help.
> Lorenzo
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> ( tautges at mcs.anl.gov ) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
