[MOAB-dev] r5167 - MOAB/trunk/tools/mbzoltan
hongjun at mcs.anl.gov hongjun at mcs.anl.gov
Fri Sep 16 15:48:47 CDT 2011
Author: hongjun
Date: 2011-09-16 15:48:46 -0500 (Fri, 16 Sep 2011)
New Revision: 5167
Modified:
   MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
Log:
o geometry partition can partition surface too
o passes make check
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.cpp	2011-09-16 19:20:17 UTC (rev 5166)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.cpp	2011-09-16 20:48:46 UTC (rev 5167)
@@ -986,10 +986,8 @@
   DLIList<RefEntity*> entity_list;
   if (dim == 0) gti->ref_entity_list("vertex", entity_list, CUBIT_FALSE);
   else if (dim == 1) gti->ref_entity_list("curve", entity_list, CUBIT_FALSE);
-  else if (dim == 2) gti->ref_entity_list("surfface", entity_list, CUBIT_FALSE);
-  else if (dim == 3) gti->ref_entity_list("body", entity_list, CUBIT_FALSE);
   else {
-    std::cerr << "Dimention should be from 0 to 3." << std::endl;
+    std::cerr << "Dimention should be from 0 to 1." << std::endl;
     return MB_FAILURE;
@@ -999,7 +997,7 @@
   for (i = 0; i < n_part; i++) loads[i] = 0.;
   entity_list.reset();
-  for (i = 0; i < n_entity; i++) {
+  for (i = 0; i < n_entity; i++) { // for all entities
     RefEntity* entity = entity_list.get_and_step();
     TopologyEntity *te = CAST_TO(entity, TopologyEntity);
@@ -1027,6 +1025,30 @@
+    if (part_surf) { // also get shared procs from parent surfaces
+      DLIList<RefFace*> parent_faces;
+      (dynamic_cast<TopologyEntity*> (entity))->ref_faces(parent_faces);
+      int n_pface = parent_faces.size();
+      parent_faces.reset();
+      // get shared processors from parent faces
+      for (j = 0 ; j < n_pface; j++) {
+        RefEntity *parent = parent_faces.get_and_step();
+        TDParallel *parent_td = (TDParallel *) parent->get_TD(&TDParallel::is_parallel);
+        if (parent_td != NULL) {
+          DLIList<int>* parent_procs = parent_td->get_shared_proc_list();
+          int n_shared = parent_procs->size();
+          parent_procs->reset();
+          for (k = 0; k < n_shared; k++) {
+            int p = parent_procs->get_and_step();
+            s_proc.insert(p);
