[MOAB-dev] r5166 - MOAB/trunk/tools/mbzoltan
hongjun at mcs.anl.gov
Fri Sep 16 14:20:18 CDT 2011
Author: hongjun
Date: 2011-09-16 14:20:17 -0500 (Fri, 16 Sep 2011)
New Revision: 5166
Modified:
MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
MOAB/trunk/tools/mbzoltan/MBZoltan.hpp
MOAB/trunk/tools/mbzoltan/mbpart.cpp
Log:
o ghost option is added to add ghost geometry for geomtry partition
o passes make check
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2011-09-16 18:31:34 UTC (rev 5165)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2011-09-16 19:20:17 UTC (rev 5166)
@@ -247,7 +247,8 @@
const int part_dim,
const int obj_weight,
const int edge_weight,
- const bool part_surf)
+ const bool part_surf,
+ const bool ghost)
// should only be called in serial
if (mbpc->proc_config().proc_size() != 1) {
@@ -446,7 +447,7 @@
else {
#ifdef CGM
result = write_partition(nparts, entities, assign_parts,
- obj_weights, part_surf);
+ obj_weights, part_surf, ghost);
#endif
@@ -642,7 +643,8 @@
DLIList<RefEntity*> entities,
const int *assignment,
std::vector<double> &obj_weights,
+ const bool ghost)
ErrorCode result;
@@ -716,7 +718,7 @@
int merge_id = TDUniqueId::get_unique_id(entity);
TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
if (td_par == NULL) td_par = new TDParallel(entity, NULL, &shared_procs,
- merge_id, 1);
+ NULL, merge_id, 1);
if (debug) {
std::cout << "surf" << entity->id() << "_is_partitioned_to_p";
@@ -735,7 +737,7 @@
// partition shared edges and vertex
- result = partition_child_entities(1, nparts, part_surf); RR;
+ result = partition_child_entities(1, nparts, part_surf, ghost); RR;
result = partition_child_entities(0, nparts, part_surf); RR;
return MB_SUCCESS;
