[MOAB-dev] r5161 - MOAB/trunk/src/parallel
xbxu at mcs.anl.gov
xbxu at mcs.anl.gov
Thu Sep 15 10:16:32 CDT 2011
Author: xbxu
Date: 2011-09-15 10:16:30 -0500 (Thu, 15 Sep 2011)
New Revision: 5161
Modified:
MOAB/trunk/src/parallel/SharedSetData.hpp
Log:
fix a typo
Modified: MOAB/trunk/src/parallel/SharedSetData.hpp
--- MOAB/trunk/src/parallel/SharedSetData.hpp 2011-09-14 15:28:40 UTC (rev 5160)
+++ MOAB/trunk/src/parallel/SharedSetData.hpp 2011-09-15 15:16:30 UTC (rev 5161)
@@ -133,7 +133,7 @@
typedef std::map<unsigned,ProcHandleMapType> RHMap;
- typedef std::set<std::vector<unsigned>,less_vect_indr> RProcMap;
+ typedef std::set<std::vector<unsigned>,less_vect> RProcMap;
#endif
/** Map for lookup of ProcHandleMapType instance by rank */
