[MOAB-dev] merge question
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Sep  7 09:10:57 CDT 2011
I can't think of any reason why that needs to happen...
- tim
On 09/07/2011 09:05 AM, Iulian Grindeanu wrote:
> Hello,
> I have a question about merge_entities method in moab::Core
> ErrorCode Core::merge_entities( EntityHandle entity_to_keep,
>                                         EntityHandle entity_to_remove,
>                                          bool auto_merge,
>                                          bool delete_removed_entity)
> Somewhere deep during the adjust adjacency call( aEntityFactory->merge_adjust_adjacencies(entity_to_keep, entity_to_remove) ),
> some new entities are created, and I am not sure why.
> Is it because of overabundance of caution?
> During merge_adjust_adjacency call, a call to check_equiv_entities is made, in which a call to "result = create_explicit_adjs(*rit_rm);" is made. At this point, if 2 nodes are merged, all the adjacent entities to each of the nodes are created, even though none might have existed before the merge (so, when you merge hexas, all quads and edges are created, connected to the hexas at  the interface)
> I am trying to understand the reasoning, and I think I am missing something.
> Any help?
> Thanks,
> Iulian
> // check for equivalent entities that may be formed when merging two entities, and
> 1322 // create explicit adjacencies accordingly
> 1323 ErrorCode AEntityFactory::check_equiv_entities(EntityHandle entity_to_keep,
> 1324                                                  EntityHandle entity_to_remove)
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
