[MOAB-dev] r5141 - MOAB/trunk/test/obb
Tim Tautges tautges at mcs.anl.gov
Tue Aug 30 16:41:33 CDT 2011
I'll get that one; don't know why it passed the tests before...
- tim
On 08/30/2011 04:36 PM, Iulian Grindeanu wrote:
> I think that h5portable has the same issue?
> $ h5portable
> Running test_native_read ...
> Attempting to use an MPI routine after finalizing MPICH
>> Author: kraftche
>> Date: 2011-08-30 16:30:00 -0500 (Tue, 30 Aug 2011)
>> New Revision: 5141
>> Modified:
>> MOAB/trunk/test/obb/Makefile.am
>> MOAB/trunk/test/obb/obb_test.cpp
>> Log:
>> yet another test that needs to call MPI_Init and MPI_Finalize even
>> though it doesn't do anything parallel
>> Modified: MOAB/trunk/test/obb/Makefile.am
>> --- MOAB/trunk/test/obb/Makefile.am 2011-08-30 18:14:08 UTC (rev 5140)
>> +++ MOAB/trunk/test/obb/Makefile.am 2011-08-30 21:30:00 UTC (rev 5141)
>> @@ -5,7 +5,8 @@
>> AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
>> -DMESHDIR=$(MESHDIR) \
>> - -I$(top_srcdir)/src -I$(top_builddir)/src -I..
>> + -I$(top_srcdir)/src -I$(top_builddir)/src -I.. \
>> + -I$(top_srcdir)/src/parallel -I$(top_builddir)/src/parallel
>> LDADD = $(top_builddir)/src/libMOAB.la
>> Modified: MOAB/trunk/test/obb/obb_test.cpp
>> --- MOAB/trunk/test/obb/obb_test.cpp 2011-08-30 18:14:08 UTC (rev
>> 5140)
>> +++ MOAB/trunk/test/obb/obb_test.cpp 2011-08-30 21:30:00 UTC (rev
>> 5141)
>> @@ -6,6 +6,10 @@
>> #include "moab/GeomUtil.hpp"
>> #include "moab/CN.hpp"
>> +#ifdef USE_MPI
>> +#include "moab_mpi.h"
>> +#endif
>> #include<iostream>
>> #include<sstream>
>> #include<stdlib.h>
>> @@ -119,6 +123,11 @@
>> int main( int argc, char* argv[] )
>> +#ifdef USE_MPI
>> + int fail = MPI_Init(&argc,&argv);
>> + if (fail) return fail;
>> +#endif
>> std::vector<const char*>  file_names;
>> bool flags = true;
>> for (int i = 1; i<  argc; ++i) {
>> @@ -204,6 +213,11 @@
>> for (unsigned j = 0; j<  file_names.size(); ++j)
>> if (!do_file( file_names[j] ))
>> ++exit_val;
>> +#ifdef USE_MPI
>> + fail = MPI_Finalize();
>> +#endif
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
